Gswest236
Thanks Jim. Are you referencing the clutch alignment tool or something different to check bell housing alignment?
Gswest236
I got the carb rebuild started; everything has been removed that needs to be removed. It's all bagged and tagged. The Chinese Amazon carb rebuild kit that I got first probably would be fine for those that do these rebuilds all the time. The Edelbrock kit came with instructions which a guy like me needs. Got the clutch assembly out and it looks like the flywheel should get resurfaced, the pressure plate and disc will be replaced. The transmission will get cleaned up next.
Gswest236
I got the carb done today. Was waiting on a new accelerator pump from Edelbrock; their kit didn't have one. The Chinese kit had one but of course it didn't work with the stock S clip. For anyone doing a rebuild on one of these carbs; don't waste your time with an Amazon cheapy rebuild kit. Next question is do I need this heat shield? My guess is any heat abatement around the carb is worthwhile. Does everyone use them with these motors?
Scott, With the Jet Hot coating on the intake and headers the carb should be cooler. I've never used a plate but have used a double gasket with an aluminum shim in the middle. You could cut the plate down for a spacer sandwich.
Many use a phenolic spacer.  They come in several sizes.  A 1/4" or 1/2" should fit.
Gswest236
I have a 1/2" phenolic spacer and it seemed to help with vapor lock. But it caused the air filter housing to touch the hood, but just slightly. I was thinking with the ceramic coating I might not need it. After getting the hood louvered, engine temps were fine. But I haven't been in stop and go traffic on a hoy day, which would be the true test. I'll probably put the spacer and heat shield back on before I'm done.
Gswest236
We got the transmission and crossmember cleaned up. 17 years of grease and grime gone. Need to order the clutch parts; disc, pressure plate , throw out bearing. Being a Rover tranny and bell housing, who has the right stuff? Also, I want to change the fluid in the 5 speed. Factory recommends ATF, but I see info on 75w90 being an upgrade. What's the consensus here?
Scott, Check Rockauto under Rover and Land Rover. Triumph TR7 &TR8 used the Rover transmission also. Rimmer? I'd use Synchromesh Fluid.
Gswest236
I'm told it's the LT77. TWS motors has the clutch kit coming my way.They wanted pics of my flywheel and clutch disc and plate before confirming they had what I need. So we're good but slightly poorer. I tried Rimmer Bros and it was too much with shipping. Rock auto/summit probably have what I need but I didn't see it there with the 10" disc and 23 spline. I don't mind supporting these shops that aren't giant businesses. In the meantime I'm cleaning the engine bay and doing some touchup work.  Most of it is good, but very oily.
I would run the ATF in the LT77 vs the 75w90.  The fluid pump may not like the thicker oil.
Gswest236
I got the fluid changed out in the 5 speed. I went with Valvoline Synchromesh. Since I'm waiting on the headers and clutch parts I decided to spruce up the engine bay. All the chips and touch up paint spots looked bad, so we'll see if it looks better or worse when I'm done. It's a 50/50 proposition at best.
Gswest236
Not a paint and body guy by any means, but I did get the first coat of base color on and it  needs another to cover everything. Hope we cleaned it and scuffed it enough! We've got the clear coat ready to go.
Gswest236
I did a coat of clear in the engine bay and will do another light coat tomorrow. I'm happy with the look so far and fingers are crossed that the paint will stick. Cleaned the crap out of it, but I've read that the base coat should be sprayed 12 to 24 hrs after spraying the primer or it may peal after 3 to 6 months. I may have missed that window by a day. The point that they make is if you spray within that window you will get a chemical bond. After that window you're supposed to scuff the primer to create a mechanical bond. Did I mention I'm not a paint and body guy?
I did get the Flywheel resurfaced (Horsepower Machine, Bremerton) and it looks like we should be getting the clutch installed pretty soon.
Gswest236
I ordered a cheap engine cradle; it has to be modified, of course. So, I got a temp engine cradle situation. But we did get the flywheel on. Knowing it's balanced, I was worried if it could be mounted out of balance by an idiot. Luckily it's idiot proof, so it's on and torqued to spec with thread locker.
Gswest236
Thanks Jim, I had a moment of panic when installing the new pressure plate to the flywheel. I hadn't noticed when removing the old one that the springs were compressed when fully installed. So, when I went to install the pressure plate I'm like This doesn't fit around the disc. I had to get the old ones out to compare and luckily they were the same. So, AI told me the springs compress as you tighten it down, Whew!
Transmission, bell housing, throw out bearing here we go!
Gswest236
I have to block this thing with something to get to the 60 lbs torque on the connecting bolts. I'll try the wife, she's strong.
Gswest236
Once I got the hoist working (needed a little fluid), I got the transmission attached. The next step will be a bit of a struggle.  I have no choice but to beg the wife for assistance. This thing needs to find its home. Of course the fresh paint will be an issue.
Gswest236
Gswest236
Attempt #1, Fail! The car was on jack stands when I took the motor out. I swapped the front jacks out and put some cribbing under it. Its an inch too close to the ground for the hoist legs to roll under.  So, I jacked it up and put in some 2X4's to raise it up. Next I'm trying hooking one of the 3 openings in the manifold lift plate without the load leveler to see if I can get the angle right.
