LS4 Into an MGB
Started by Scott Costanzo, October 22, 2013, 09:12:39 PM
ex-tyke
Quote....increases the odds of making Indy
Hang in there Scott - we're all rootin' for ya!
Scott, Almost there! Can you replace the bolts you ground with pan head Allens? I would use hardened washers under the heads.
Capt'n Moorgone
Great news Scott! Some times all the planets line up for you. Hope to see you in Indy.
Scott Costanzo
Thanks Graham, Jim, and Mike! Just to be clear, both Artie and I will be in Indy car or no car. Our wives will even be there for a short time. It's such a fun event and the people are first class! Wouldn't miss it! Not to jinx anything but the car is where I hoped it would be at this point so I'm optimistic it will be ready too.
Jim, I'm not quite sure I understand your question. The picture I took shows the back of the flywheel and you're looking at one of the pressure plate bolts before any grinding took place. One of the starter bolts just happened to occupy the same place that the pressure plate bolts do. What bolts are you referring to?
Scott, I didn't see the shiny spot by the ring gear and assumed the pressure plate bolt heads were rubbing. Looking forward to your first test spin!
74ls1tr6
Scott,
Photo's of 98 S70 Volvo fan with relay! Photo's should give you an idea of dimensions, that maybe can work with your application.
About 17 1/2' width across furthest.
2 speed relay!
Mounting would need some spacer away from radiator for fan blade...maybe 1/2"
Total from out most fan blade center to fan motor is 3 3/4" or less
74ls1tr6
That's the same fan & relay pack I'm using.  It's never even gone to high speed even in Texas heat with the A/C on.  I can definitely recommend it if the Lincoln one won't fit.
Scott Costanzo
Thanks for the suggestions Calvin & Rob. Calvin, I'll be in touch with you next week.
Artie was in and we had a great time as usual. I really want to thank him for all his help! He's a really good friend and a great guy. We got a lot of work done on the car. We didn't get it out on a long run like we hoped but we are very close now. We did do a short first run and got a couple of videos showing it. Here is the drive by.
<iframe width="560" height="315" src="https://www.youtube.com/embed/eSq3GBjnm3Q" frameborder="0" allowfullscreen></iframe>
The car is still rough in this video but it was very fun getting it out even for a few minutes. Can I officially call this a V8 car now?
As I said, we got a lot of work done. The throttle pedal is in and adjusted, the PCM is installed permanently, the new fuel pump is finally installed and the radiator ducting is well on it's way to being complete. I have a distinct lack of pictures and I apologize for that...just too busy working to get things done. I didn't even get a picture of Artie!
I still have a few things to do besides completing the radiator ducting:
o Fix a pesky leak at the thermostat housing
o Adjust the tach for the V8 (the PCM actually puts out a 4 cylinder signal I'm told)
o Put the interior back together and clean things up
o Do a bunch of minor tasks here and there
Here is the current state of the engine bay as of last night.
I'm very hopeful for the meet. It seems like the odds favor the car being ready for Indy unless something major goes wrong. It will NOT be "done" at all. There will be incomplete things that will need to be redone. Everything I'm doing now is just to make it as reliable as possible. I really need to get it out on the road and put a few hundred miles on it. Hopefully next weekend.
Scott
74ls1tr6
Was that a BIG GRIN on your face Scott when you drove by :)
BWA
Scott that is pretty awesome!!  You are just about ready to run with the "big boys" now.
If I ever do another project it might be an LS4 in to a TR4 or TR4a.  You are blazing a path for others to follow.
Thanks for the detailed thread on this topic.
Byron
MGBGT?
Scott, thanks for allowing me to participate in your build experience.  It's a pleasure working with you.  Hang in there.  When I'm back in 5 weeks, we'll finish up the important details you haven't gotten a chance to address & I'll do the detailing of the car for you.  After all, she must look her best.
I thought we fixed the leaky thermostat?
Scott Costanzo
I'm still grinning Calvin! :)
Thanks Byron, it's fun to share it with fellow car guys. Oh, I took your advice and adjusted the throttle cable support so the angle isn't so severe.
Artie, yeah, so did I. I looked after we started it yesterday morning and it's leaking slightly again. I'ii try to tighten it again to see if that helps. If not its on to plan B. :)
Great to see Scott, and yes definitely official. I imagine you'll be giving a few rides at Indy.
Can't wait to see it.  I'll be in line for the rides at Indy :)
By the way... talk about a sleeper.  Looks totally stock.  Even looked like single exhaust - or at least both exiting the left side.  You are going to surprise a lot of folks :)
74ls1tr6
Scott,
That is correct about your Tach being switch to a 4 cylinder. This is what mine is set to. We are both using the same computer.
Is your engine hunting for idle as soon as your car starts rolling? In one of your video's, I though thats what I heard?
We could maybe fix that in your tune!
Scott Costanzo
Thanks everyone. Jim B., I hope I can give some rides next month.
QuoteIs your engine hunting for idle as soon as your car starts rolling? In one of your video's, I though thats what I heard?
Calvin, I didn't think that was happening but you could be right. Keep in mind that the video was taken on Friday afternoon before most of the work was done. We replaced the fuel pump and updated the wiring in the tank as well early on Sunday. When we started it for the first time after all the work on Monday morning, just before Artie left, it ran like a different engine. We're still very early into the sorting out phase. I will keep everyone informed. Please keep the comments coming, I appreciate your insight!
Gonna be a hoot!
<iframe width="560" height="315" src="https://www.youtube.com/embed/R5xTxMYWvXI" frameborder="0" allowfullscreen></iframe>
Scott Costanzo
Carl, I hope I don't experience the fire part of that video! :)
Time for another update.Finally got the car out for about a 20 minute drive in the country. Actually made it back home without incident so that was good. The temperature ran a little less than 200 F so I was quite pleased with that. As you'll see below, the ducting isn't quite complete yet so that is encouraging. The temperature was in the mid 80's F during the drive. I have not taken it out on the freeway to get it really warmed up and then allowed it to sit still for any period of time after that so there are still quite a few unknowns cooling system wise. So far so good.
Here is a picture of the engine bay in what I believe will be the "final" Indy state. Still need to paint the ducting but I can't think of anything major left to do here.
Artie and I co-designed and built this and I'm quite pleased with the way it turned out. It isn't perfect but it isn't too bad all things considered. This next photo shows the frame for the lower ducting.
I didn't have to drill any holes to mount this so it fits in well with my theme of minimal modifications. I'm using a couple of the sway bar mounting bolts and the rearward front bumper bolts to hold the thing on. I was going to cut some sheet metal for the skin to cover this frame but after thinking about it I'm going to use some coroplast because it will be easier and just as effective I think.
So the drive uncovered some additional "sorting out" issues. I got a check engine light with three trouble codes. Two were knock sensor related and the remaining was the cam sensor. It has been difficult to start at times and the symptoms it is showing fall into line with the cam sensor problem. I'll have some troubleshooting to do for this one. I'm not surprised the knock sensors are throwing a code but I'll save that issue until I get the cam sensor fixed. Should be interesting. Inch by inch.
Scott Costanzo
OK, time is getting short. I figure I have 4 working days left before the meet counting the Tuesday before we leave. I'm still cautiously optimistic we'll make it. Additional progress was made over this past weekend. I pretty much completed the lower ducting, except for paint and a few miscellaneous tasks. Painting it may or may not happen at this point but you can't really see it from most angles. Here's one side.
It's a little bright :) but what you are looking at survived a couple of 70 mph runs no problem at all. So far so good. It took an incredible amount of time for me to make it. Probably somewhere between 6 to 7 hrs. total. It doesn't really look like it should take that long. If I used a metal skin it probably would have added at least another hour. Maybe down the road. So I took it out for a few tests to see how the upper and lower ducting worked and, all things considered, I'm pretty pleased. I got it fully warmed up and then took it for about a 15 mile cruise on the freeway at about 70 mph. The temperature, according to the factory coolant temperature sensor, ran about 205 F. with the air temperature in the mid to upper 80's F. Seemed to be pretty steady. It never got above about 215 F coming back home on residential streets at about 25 mph. The interesting thing is the factory temperature sensor isn't very accurate. When it's cold, it reads a good 10 degrees above the ambient temperature in the garage when compared to my wife's temperature display in her car and to the incoming air temperature sensor. I'm not sure if that difference is linear as it gets warm. I'm hoping that someone at the meet will have an infrared  gun they can test my radiator with. I could potentially be running around 195 F with a high of 205 F.
I was able to get the cam sensor wiring squared away pretty quickly. The first test I did identified the problem. This may help someone down the road so I'll mention briefly exactly what this issue is about. I'm using the 0411 PCM that was flashed with LS1 code. The LS1 has a rear mounted cam sensor. My LS4, like the LS2, has the cam sensor mounted into the timing cover at the front of the block with no option for a rear mounted sensor. I went to an LS2 front cover and the LS2 cam sensor. The plug for both the LS1 and LS2 cam sensors are the same...works out great except that the order of the wiring in the plug changed. There are 3 wires in the plug, the sensor signal, a 12 volt reference, and a low (ground) reference. In the LS2 sensor the sensor signal and the 12 volt reference are switched when compared to the LS1 sensor. So I knew this when I built the harness and I thought I had accounted for it. Guess not because they weren't switched. I'm beginning to think I did the crank sensor instead of the cam sensor by mistake. The two plugs look identical. You might recall if you've been watching this thread for a while that I had a no start issue caused by a crank sensor wiring problem. It was switched and now I find the cam wasn't. Oh well. It was an easy fix at least. It starts much better now as you can imagine and the code is gone. I discovered another wiring issue the other night. It seems that one connector on the ignition fuse is deformed slightly and it's causing an intermittent issue. I'm going to replace it this coming weekend and hope that is the end of my wiring issues.
I really haven't had time to play with this much yet but I'm trying to get the wide band sensor data into my TunerPro logs by trying different, unused outputs that are included in the OBD2 ALDL output. I got the brilliant idea of trying the air conditioner pressure wire. So I start the car and about 30 seconds later the cooling fan comes on. It seems that's how the computer knows if the air con is running or not. I had to laugh. It appears the wide band controller is putting out some voltage at least. What I'm trying to do may not be possible but trying further will have to wait until after Indy.
I finally got some time with the car on the road. I've put close to 80 miles on it so far. It's fun. I don't think of myself as one of those guys that select an engine just for the sound. I love the sound of all sorts of engines. I think the original B motor sounds great as a matter of fact. But I grew up lusting after Camaro's, Chevelle's and Corvette's. Back then, as a 14-15 year old kid, watching one rumble down the street got my blood boiling. So listening to the LS4 while going down the road brings back the notion of how I think a performance car should sound. Kind of hard to explain and I didn't mean to get all philosophical about it. Bottom line, it sounds great....like it means business as you go through the gears. The torque is unreal! According to the factory dyno chart it gets above 300 ft. lbs. at something like 1800-1900 RPMs. Going down a residential street in third at 20-25 mph and accelerating is effortless, the engine hardly sounds like it's working. Absolutely no problem breaking the tires loose in third. It's going to be fun learning about how this new motor has changed the car. I haven't driven the car hard at all yet either. Got to be careful I don't kill myself with it!
If things continue to progress like they have so far, Indy should be doable. The car is by no means sorted yet especially when I compare it to how sorted Mike Moor's car is. That is my benchmark. Mike's car is the best sorted conversion I've ridden in to date. I'm a looong way from that point. I don't think I'm going to be able to compete in the autocross and that will be a little disappointing.
Looks like I wrote a novel so I'll close for now.
74ls1tr6
I'm bringing my infrared gun.... :)
Scott Costanzo
QuoteI don't think I'm going to be able to compete in the autocross and that will be a little disappointing.
C'mon Scott, I bet we could sell tickets to the drift event!  :)
