Clutch Pressure plate for Buick 215 V8
Started by vljohnson86v@yahoo.com, September 21, 2019, 05:09:58 PM
I have been trying to find a pressure plate for my 1961 Buick 215 V8, stock light flywheel. I would like to find a stock one so no mods are required to the fly wheel. I'm adapting a T5 Ford WC, 1352-169, and will use a clutch plate with a 10 spline, 1 1/16" center for the T5.
Can anyone point me in the right direction?
Virg
Virgil, What you need is a 10" Ford Long pattern Diaphram pressure plate. Ram list it for 64-79.
jjohanski
The GM late (say for a Camaro) V6 pressure plate and clutch also works.  This gives a light pedal and still handles the HP.  I believe a may have one in my stash.  PM me if you are interested and I will seek it out and send you pictures.  It is new and complete.
My TR6
James, He has a Ford T5. Clutch splines are different. The Ford pressure plate I mentioned bolts right up. The Camaro pressure plate would have to have the flywheel redrilled to fit.
