Removing aluminum corrosion
Started by relative4, February 15, 2016, 12:17:35 AM
relative4
I need to replace the timing cover on my Rover 3.5, and I have a spare that's been sitting around a long time.  It's never been used, but it has accumulated a bunch of aluminum oxide that needs to come off before I can use it.  Any recommendations on a good solution?  Hopefully a spray to get into all the nooks and crannies?
Might try good 'ole vinegar for a start. Commercial aluminum cleaners are, I think, muriatic acid based.
Then there are the CLR products that might have a suitable solution.
Edit: If it were mine, I'd get it bead blasted.
I'm with Graham. Bead blast it.  I have a friend that used to spiff up his aluminum intake with Brillo pads.
relative4
I assumed bead blasting would compromise the mating surfaces.  Not so?
If it's done properly, one can easily avoid blasting the side/mating surfaces.
 I've done a few front covers and intake manifolds without any issues.
kstevusa
JUST BLAST IT WITH NUTS!    shells :-)
