Wheel/tires w/sebring flares
Started by t.lay, July 28, 2008, 01:32:40 AM
t.lay
Bill,
There is the sportmax 941 - similar to the xxr - 10 spoke that does come in 5 x 4.5 - may not have the offset though.
classic conversions
Found the wheel that I will be using on my RD 16X8 4" back space and 16X7 4" backspce on 5X4.5 bolt pattern
http://www.etwheels.com/ac/
Damn you Bill,
            Those Cobra wheels are what I had envisioned on my conversion one day.....looks like you beat me to the punch!  Very nice indeed and reminiscent of the MGB-GT/Ford 289 conversion I remember seeing back in1967 at the BMC dealership in Hamilton, Ont - it also had Cobra Halibrand KO's.........(insert deep sigh here!)
t.lay
Nice find Bill. It's a good looking design and nice to see one so customizable. I'm gonna drive myself nuts on this until I pull the trigger on wheels/tires. If this weekend goes well on firewall mods - maybe next week. Worst case is by the beginning of Sept. I should make up my mind.
classic conversions
Sorry Graham. They also have the pin drive bolt on kit. mmmmm!!!!
Also look at the LT III wheels, they also come in different offsets. Minilites with a deep dish on the rear.
Those wheels are very similar looking to the ones I got from american racing (427P's) but AR doesn't do them in 16".  That would have made finding tires way easier!
t.lay
OK taking another run - not having much luck nailing down rims with mixed widths in 16". Whose running 17" rims?
The thought - ASA AR1s 17x8 on the rear with 245/40/17 and 17x7 up front with 225/45/17s - keeps the circumference at 24.7" in the rear and 24.6" in the front. Getting a little thin on the rubber though. Also started sourcing parts for a fabricated x-member (mustang II spindles, tubular a-arms and rectangle tubing for the x-member).
Any experience out there w/17s?
Very little. We discussed 17's on the Roadmaster thread a few pages back, I think we decided on 275/35 or 40-17's for the back and 225/45-17's on the front. I bought a set of 315/35-17's for my roadster but they're on the Roadmaster right now and probably will be until I get my IRS completed. So we've not driven on them yet.
Check out Evan Amaya's car in the photo gallery.  He has 17's IIR.
t.lay
A little less rubber than I think is ideal - but lots of tire choices and I'm getting to a point of overthinking it. Think I'm just going to pull the trigger and get on with it.
Yeah, I was just thinking that'd give you a feel for how well the 17" wheels/tires "fit" from a diameter perspective.  You'll be using flares if i recall so you can go wider of course.
t.lay
I like Evan Amaya's car, esp. the rounded rear wheel arch - more modern - but thinking those 205s will look kinda skinny with flares. I promised myself I'd figure it out this week - so I placed the order: ASA AR1s (pretty much flumoxed the tire rack rep with the mustang/granada bits). Now I just have to make it work.
what size & backspace AR1's did you get?  And tire size?
MSDMGBV8
I tried to get those AR1 for my 2005 WRX STi but they didn't have them with adaquate backspace to clear the Brembos. I really like those wheels.
Didn't you mean "flummoxed"?
t.lay
I went with 17x8s on the rears with 245/40/17s - rear wheels have a 35mm offset (about 5.75" backspace) - 24.7" diameter
17x7s on the fronts with 225/45/17s with a 48mm offset (somewhere around 5.75" backspace also) - 24.6" diameter
tires are hankook ventus RS2s
Could have gotten smaller backspacing on the fronts with silver wheels instead of black (down to a 28mm offset)- go figure.
since I decided to build my own x-member and using a ford rear that will have to be shortened - I didn't worry too much on the offset - on the front, I think it's going to work out pretty well with little scrub radius - so fairly wide tire with relatively low steering effort - we'll see. I was intrigued by one of the posts on the experience - where someone moved the front axle centerline forward 1.5" - perhaps a little extra space for header/tire clearance.
YoungGuy
Ok, so I respect the fact that your car is your personal statement and style is individual but I have to say that most of this discussion seems to be going in the wrong direction. 17's on an MGB? Please, please, please, no. 16's with the right tire profile, maybe but, 17s and above would make it look like a wagon and the body lines cant hold wheels that big. That blue MGA made me throw up in my mouth a little and I am not the only one to think this. I am in no way a purist, in fact I love modifying these cars (72 MGB GT getting a 13B Turbo and an MGA getting a Ford Zetec) but at some point someone needs to say whoa. That thing does NOT need wheels that big and I can not imagine that they are any improvement in handling. MGAs are made for 15s and possibly 16s, if they are the correct style. That red GT is sweet but please dont be afraid of lower profile tires. It looks like a truck. Drop the profile down to 45 or something and itll sit much nicer, plus handle better.
Thanks for letting me know what my allowable personal style is.  I'm sure I was fretting that. :)
Bruce Mills
I don't have Sebring Flares but this shows what can be done with larger rims and smaller tires. Fronts 225/45/17 Rears 245/40/17. Using Omni Flares
I am afraid I can't give you guys any more info at the moment as all my car stuff is packed away for moving. But once I get set up I will up date my info in the Photo Gallery
Bruce
YoungGuy
I am not trying to tell you what to do and I am into modifying a car but at a certain point, it doesnt look that good anymore. Maybe the bigger is better movement has moved on from the younger crowd to the adults. I had a MKII VW and anything over 16's, and they had to be the right 16's, was laughed at. It just didnt look right. If bigger was truly better, the people racing these cars would be running them too...
I was thinking you could probably manage to get 20's on it with the right tires. Something like a 215/25-20 would be about the right diameter and width. Bet you wouldn't get any sidewall flex with those babies!
QuoteIt just didnt look right. If bigger was truly better, the people racing these cars would be running them too...
I'm inclined to agree with you Jarrod, although I believe the road-racing/vintage-racing classes where MGB's are raced have wheel size restrictions in their rules...
Obviously appearance and performance are entirely separate issues. Some people prefer the looks of 17" wheels. That's their own preference, and it's certainly not wrong. To my eye, it just "looks wrong" not just because it isn't "period" but because from a performance point of view 17" wheels make so very little sense on an MGB, especially if carving corners is a priority.  Bigger wheels = bigger flywheels (4 of them!) = harder to accelerate = harder to decelerate = more energy wasted every time you brake and thus worse fuel economy. By the time you put tires on them, the rotating weight is usually substantially increased too. More unsprung weight moving up and down = more difficult to control with shock absorbers = worse ride quality. If you reduce sidewall height, you're looking at a less compliant ride on a car that already has a pretty uncomfortable rear suspension (unless you're replacing that... as Rob and others are.)
The funny thing about fashions is that they change constantly. One of these days, realistic wheel sizes will come back into fashion.
Re: the earlier comment about sports cars that "look like trucks"... that comment confused me because I personally love trucks. Big trucks anyway... Check out the special European ultra low profile wheels and tires on my old truck!
(p.s. This photo was taken on a frozen lake in Arjeplog Sweden where we were testing a brake-by-wire braking system. What a great truck that was! Took me fun places.)
YoungGuy
Maybe this is a fad and proper, realistic wheel sizes will come back. Nice Volvo. A friend of mines father owns one and I went to school close to one of the factories in Va. I love trucks. Ive had trucks and SUVs pretty much all of my life. I dont have one at the moment, 3 cars is enough for me at 26 right now but, will probably get one again soon. I was just saying that if you compare the red BGT with the white BGT, you will see what I am talking about. Shorter sidewalls and some lowering would make that thing look amazing.
Yes, I also believe that they are limited in terms of what size wheel they are allowed to run. At a certain point, big wheels are more a detriment than an advantage, let alone the fact that it just looks wrong. TC, TA, Midget, etc... with running boards, throw some big wires on there. Looks at home. Throw a big set of wheels on a car whose body is almost as tall as the wheel itself, horrible look. Just dont get it.
And so it doesnt seem like Im just trolling or anything, here is my GT. 72 spoke wires, lowered a little over 2" (its much lower in real life than the pics show), neg a arms, 3/4" sway bar with solid mounts, wilwood 4 piston caliper conversion, 13B Mazda w/ 5 speed in the garage waiting to be dropped in.
P.S.- Please dont put XXR, otherwise known as Sportmax, wheels on your car. They are cheap in price because they bend unbelievably easy. A lot of the MKII VW guys run these because they are cheap but first really good pothole and you are going to have trouble. If I had a choice, and the money, to throw a set of bolt on wheels on my GT, I would put these on in an instant. 15" BBS RS. They are three piece so you can choose your offset, width and lip depth, and center color. Plus, they have that mesh, wire wheel look that would work so well with an old British car.
danmas
YoungGuy Wrote:
> but at some
Who is that someone? An elected official, a self appointed regulator, a hereditary ruler, or someone annointed by God?
Will he contact us, or do we need to locate him?
Before or after we violate his decrees?
Are the rules published somewhere so we can know what we can and cannot do?
What are the penalties for failure to heed his dictates?
YoungGuy
> dictates?
Well, in case you havent noticed, that someone is me, haha. But seriously now, step back and look at them, really look at them. Look at the size of the opening on the body and compare it to these big wheels. Im not talking about period correctness or anything like that but just porportionally speaking, look at it and be honest with yourself. Does a car this small with openings shaped the way that they are, really warrant a wheel of that size? Are we trying to catch up with the ricers or DUB magazine or the current (dying) trend of wheel sizes? Are we going for a wow factor with these wheels? Everyone complains about brake fade so are we trying to add more rotating mass (unless you drop big bucks on wheels, bigger does equal more weight) so we can continue to complain about the brakes? Are we looking to diminish the "chuckability" of these cars in the twisties? My GLI has 18's on it with a modified suspension and they fit the car porportionally and greatly increase my handling ability due to the design of the suspension. Are we looking to slow the sprinting ability of our cars down (rough math says every inch equals .10 off gearing)?
Chuck and A into a corner on 18's and one on 16's and see which one comes out first. If we are looking for more traction, why are we not looking to go wider? 15x8's would do a great job and can handle the HP some of you claim to be putting out. Why should we need to look to grafting fender flares, which if arent done correctly or are of a bad outward design detract from the flow of the car, to make big wagonesque wheels fit? Wider, not taller and just because we can make them fit doesnt necessarily mean that we should...
Some automotive trends arent trends but fads and fads die out. Do we as an enthusiast group want to fall victim to following a fad and joining in with the ricer/ dub crowd or do we want to stick with a Euro/ Brit style? Massive body kits and useless wings were the thing not to long ago. Where are they now?
Perfection, on 15" wires:
Jarrod, it amuses me that you're stirring this pot. (It's been stirred many times before, of course.)
When, on the one hand you question the performance advantage of big-diameter wheels and then on the other hand you post pictures of spoke wheels...  I mean, what could possibly scream "low performance" louder than spoke wheels? Let's see how many people we can annoy this morning! It's all in good fun, right?
Your GT is very handsome, by the way. Next time you're changing tires, can I trouble you to weigh one of those spoke wheels? I'd like to build a wheel database... As I recall, the original Rostyle wheels from my 71 GT weighed about 18.3#. Alloy wheels are stiffer and lighter. Even Minators (which aren't a high performance wheel by any measure) only weigh 13.6# in the popular 14x5.5 size.
