Adding remote brake booster
Started by Jim Stabe, September 08, 2018, 02:11:12 PM
Jim Stabe
Well, I got under the car today and discovered that all the spaces I was planning to put the brake boosters either do not have enough room to fit in the rear or it leaves the unit too close to the tire in front. My fall back position is to mount them in the trunk on the shelf above the gas tank.
 I would prefer not to do that since it takes up room in the trunk and I would have to make 8 penetrations of body work with brake fluid lines and one vacuum line to make it happen and the runs would be much longer. I haven't given up entirely on the original plan but it will require moving some support members to make it happen.
What a revoltin' development, right? Sounds like there's little help for me then. I wondered about that. Well, passenger's footwell perhaps? That is usually wasted space. I used the two rear cubbies in the trunk (by the tail lights) for an air compressor and a hydropak, no help there. Might work for you though.
Jim Stabe
I thought about it and I'm willing to do some surgery in the front wheel well to get the booster to fit under the headlight area. I think I can do it by only removing one tubing brace and re-attaching it somewhere else. The plumbing for the front brakes is just too ideal not to: the engine is right there for vacuum , the output can tie into the front brake circuit at the flex hose connection and I only have to run one line through the front of the footwell from the master. The tube I would have to relocate is the one the horn is attached to and you can see from the 2nd picture it supports the outer portion of the front valance. I could possibly move it so it attaches to the upper mounting tube instead of the lower one and still retain the strength.
The rear booster would fit in the cubby behind the wheel well but would require 3 sheetmetal penetrations, not a huge deal. It would have been much nicer if I could have mounted it under the car somewhere but the chassis members back there are very structural and I wouldn't want to mess with them.
I probably won't do it until the end of October because there are a couple car shows I'm signed up for and I want to make sure the car is drivable to get to them.
ex-tyke
FWIW, my Jag MK2 had the remote servo located partially in the rhs engine bay and partially into the rhs wheel well....a removable cover was located in the well.
Wish I had photos but maybe Bill Guzman could take a photo of his MK2 servo mount.
Jim Stabe
I have room in the engine bay to fit both of the boosters but I want to keep that area uncluttered as much as possible.
Jim Stabe
I may have found another spot for the rear booster. I extended the panel in front of the deck lid forward about 6-7 inches so it covers the area where the batteries used to be and makes for a tidier cockpit opening. That created a cubby behind the passenger seat and another compartment in the center. I could cut a hole in the panel separating the compartments and mount the booster behind the passenger seat with the master cylinder portion sticking through into the center compartment. I was thinking about making a removable panel to cover up the water/methanol tank anyway so I would make it go all the way across. The tee fitting for the rear brakes is directly under the center compartment floor - handy!
Jim, could you take some shots with the booster held approximately in position for some of those locations? A little hard to visualize it.
Jim Stabe
Just getting ready to leave. I'll do it later this afternoon
Jim Stabe
I don't have long enough arms to take a really good picture but I think you will get the idea. The booster will go where the horn is in one of the pictures above. The rear one will fit in the cubby behind the passenger seat and get covered with an upholstered panel.
Jim Stabe
I went out today and thought about it some more and decided to mount both boosters in front of the front wheels. I will have to move bracing members on both sides but it will give me a few advantages. I will mount the front booster on the passenger side and be able to tie into the front brake circuit at the junction of the hard line and flex line to the right front wheel. This means that I only have to penetrate the front of the passenger footwell with one line from the front master cylinder. The rear booster will mount on the drivers side and will require 2 penetrations of the front of the drivers footwell, one for the master to booster line and one for the booster output that will connect the existing line to the rear brakes. I won't have to do anything to the existing plumbing aft of the instrument panel. Vacuum runs will be much shorter since both boosters will be right next to the engine. I will probably fabricate a vacuum reservoir out of PVC tubing that spans the distance between the two boosters to ensure braking since I have a boosted engine. I will install a one way valve between the engine intake and the reservoir to prevent boost from getting to the reservoir even though the boosters have one way valves built in - belt and suspenders.
I just finished .bolting down my freebie 2 post hoist so I will soon have that operational making the installation much easier on my old bones. I'll start another thread for the installation.
Sounds good Jim. The extra check valve will decrease your vacuum signal, but only by a very small amount, perhaps only a couple inches of vacuum, depending on what you use. Something to be aware of when selecting parts. It will affect your max braking force a little, probably not enough to matter.
Jim Stabe
Why would it decrease the signal? Once the valve is cracked open whatever vacuum level is in the intake will be the same throughout the system. There is no appreciable flow involved so whatever restriction is in the valve shouldn't cause a drop in vacuum.
Maybe...
Let's say the spring on the check valve puts 1/2 lb of pressure on the seat. Could be more, could be less. You can measure the amount of vaccuum required to unseat the valve. Certainly something more than zero, call it "x".
 Your vacuum then passing the check valve is now the manifold vacuum minus x. Just because the valve opens does not mean it does not restrict the flow and reduce the signal. No different than any other flow system. Now the force required to keep it open could be less than that required to crack it in the first place, that's worth paying attention to also.
Odds are it won't make a difference. But if you picked the wrong check valve it definitely could.
Jim Stabe
Makes sense. If it gives me a problem I'll just remove the redundant check valve.
Yeah, just get one with a light spring and high flow and I think you'll be fine. But check, some of them have much heavier springs than they need for this application.
Jim Stabe
I almost don't need a spring. The only thing the valve is for is to keep out the boost and the boost will slam the valve shut and hold it better than any spring.
IIRC the spring on the check valve that plugs into the boost canister is extremely light. And one of those would probably be the best. Another thought would be to use the canister check valve on the new tank and leave it out of the canister for the front brakes. Probably over thinking it though.
