New fuel tank pick-up
Started by BlownMGB-V8, June 18, 2016, 01:41:56 PM
Ran across the Holley Hydra Mat, a flat mat that sits in the bottom of the tank and wicks fuel to the pickup. Pretty slick idea, available in a bunch of sizes and configurations. Should eliminate the need for a swirl pot or external tank.
https://www.holley.com/products/fuel_systems/hydramat/
Edit: This'd be the one for the stock tank. Not cheap, at $200 but then again, compared to the alternatives not so bad.
https://www.holley.com/products/fuel_systems/hydramat/hydramats/parts/16-102
If I'm reading this correctly, Holley's product is just a larger version of what OEMs have been installing for many years: wicking "pre-filters" that lie flat on the floor of the tank and help prevent air ingestion. I chose a Honda Civic version for its angled connector, which facilitated fitting a Walbro pump at a 45 degree angle within an MGB tank.
Not sure Curtis, but they have a patent pending on it so I think it might be a little more than that. Those socks drain pretty easy as I remember, if you pull them out of the fuel. Did you see the video where they only had one edge maybe 1/2" in the fuel and it still didn't suck bubbles? They had the pickup several inches above the fluid level. I thought that was pretty impressive.
had to buy it
I am at the fuel delivery system stage of my Rover V8 with EFI swap. Would the HydraMat allow me to run one High pressure pump mounted in the original pump location on my BGT? Seems like a simple solution provided you can get one to fit the MG tank easily. Am I missing something?
Lorne
Lorne, that is exactly what I am thinking. The one I posted a link for above is probably going to be the best bet in terms of size, ability to fit through the sender opening, area of coverage, location of the fitting, and price point. They also have a magnet kit that attaches to the corners to stick it to the bottom of the tank. Might only want them on one or both of the long ends, or if you could see inside well enough to position it, maybe all four. I would use a 90 degree fitting pointed away from the sender hole and a relatively long flexible hose to come back to it if possible, and try to keep the fitting from flopping over on its side.
I would guess the novel feature is that the combination of wicking and surface tension allows the pad to selectively pick up fluid in preference to air and exclude bubbles as long as fluid is present. Being able to put one in the bottom of a fuel cell and then turn it up on end and still maintain 60 psi pressure was impressive, but not as impressive as the demo one they had in the clear box because in that one it had to maintain flow and you could see if any bubbles were being picked up.
Edit: If this pans out, I expect to move my Bosch 44 type pump out of the spare battery well and put it by the tank in the stock location and plumb it direct to the injector rails with no pre-filter. The return will simply go to the tank vent fitting.
had to buy it
Are the stock fuel supply and return lines large enough to maintain the right fuel pressure or are they too restrictive?
I have both a later chrome bumper tank and a RB tank. Would one be better than the other for this application?
This Holley product would sure make life easier putting my project together. Only needing one fuel pump is a benefit.
Lorne
My thoughts exactly. I'd love to reduce the complexity and get a dependable and reliable result.
Anyway, my thoughts on line size follow:
The stock fuel line is 5/16" and the return (original vent line) is 1/4. In the muscle car era, 5/16" line was used by all manufacturers to supply fuel to engines in the 300 hp range, using suction and a mechanical pump at the engine. That means the absolute maximum theoretical amount of pressure that could be applied across the line at any time was 15 psi (atmospheric) and the practical limit was probably closer to a third of that, although I have no way of confirming that theory. Most references only concern themselves with delivery pressure but it has no bearing on fuel line flow in this situation. I can only hope Graham may have some info on this.
So, the analysis is greatly dependent on whether we are considering a carbed or EFI application, also if carbed with a regulator in the engine compartment it would be more akin to the EFI install.
But if we take 300 hp at a 15 psi delivery pressure as the baseline it gives us some overhead. OTOH, this inevitably leads us to conclude that for a carbed electric pump installation with the pressure regulated at the pump and 300 hp the 5/16" line might be inadequate, and I don't honestly believe this to be the case. The truth will lie somewhere between the two.
Now, if you put your regulator in the engine compartment, the pump is free to deliver fuel based on it's pressure/flow curve. For EFI that is going to be at 39 psi or better, so roughly at least three times the vacuum that the mechanical pump can draw. In general, tripling the pressure should triple the fuel delivery so the same 5/16" line should be adequate for 900 hp or possibly more. Therefore in an EFI system it should be big enough. This also helps explain why we aren't seeing larger lines in modern cars.
The return is another question. At full power the fuel requirements of the engine are subtracted from the delivery volume and the remainder is returned to the tank. The 1/4" line is a restriction, but I have not found it to be a problem. Obviously any pump will be happier with less restriction and last longer and there is not much of a disadvantage in running larger lines, so above 300 hp it may be a good idea to enlarge both runs but below that I wouldn't bother. If however you fit a huge pump it will be working against this small line and that isn't a good thing.
As for the tanks, the best would be if you have a supply, a return, and a vent line. That way you can reduce fuel spillage and consider a charcoal canister to collect fuel vapors, or at least run a vent line up high (like across the top of the trunk) where cornering forces will not be able to push fuel out. I believe some of the later tanks had a supply line in the sender? So a careful choice of tank and sender can give you that. It's easier to cap an unused fitting than to add one.
I have a Bosch 44 clone in my spare battery box, you can get those for $30-50 on ebay and they are pretty good pumps, especially for the money. Suitable for EFI, so they need a regulator whether used for EFI or a carb. A return flow regulator would be best in this situation, I currently do not know how well one would work with a non-return regulator, but line pressure would be up around 100 psi.
mstemp
Just a few comment on this.
How are you going to get the mat inside the tank without cutting it open? Great that the magnets are available but placing them through the sending unit hole is not very likely is it?
Who is volunteering to cut open an old tank? Yes it can be done safely but no thanks. Fill with water etc but then more rust will start. Then how do you fit a cover plate? More costs.
Or start with a new tank. Consider that most of our tanks are very old and how many are actual rusted this is the better way to go. I took mine out this weekend and even though I am in a dry climate, keep the tank full when stored, it had some internal rust at the inside top portion.
So if we price out a new Specter tank ($200+), Holley mat ($200), and then a pump ($50-150) are we not close to the tank from Todd, available through Brian? I bought mine years ago and have finally started my FI conversion so in it went. Hope it works well. No I don't get anything for recommending this tank I just think it solve the tank issue fairly easily.
kstevusa
Jim, the 5/16" delivery line was adequate to deliver fuel to my 5.0L ford (275 RWHP & 305 Torque).  There was NO deviation in my A/F mixture across the RPM band.  The Malibu GM pump provided fuel to the FPR on the rail set at 39 PSI.  I fabbed a 5/16 return line to return to the pump canister.  An inline GM threaded (std 98 Truck) fuel filter was used.  It was surprising the V6 pump provided adequate fuel, but one cannot argue with the results.  Info provided for use regarding OEM tanks and GM OEM fuel modules.
Mike, if you looked at the second link, the mat is formed in the shape of a cross so by folding it there should not be much trouble with fitting it through the sender bung, even with the magnets and fuel line attached. But since I haven't tried it yet I can't say for certain. Getting the fuel line hooked up to the inside of the outlet might be a bit more tricky, it might have to come out through the sender. I don't know why anyone would want to cut open their tank to do any of this though. I was thinking with a flashlight and a stick (and maybe a mirror) you should be able to position the mat.
Did Todd's tanks come with a fuel pump installed? I wasn't aware of that. Makes the price seem more reasonable at least.
In any case, the mat should benefit any tank, even Todd's I would think.
And the idea here was to eliminate most of the complexity and cost of going from a serviceable OEM tank to a usable EFI configuration since that's what most of us dealing with this issue are facing. If all you have to do is buy a $50 pump and add this $200 mat and everything works as normal I'd think a lot of people would consider that a win. Might even be able to do it without removing the tank from the car.
Cutting into an MGB fuel tank isn't a big deal. (It's very thin steel.) I drilled a small starter hole, used aviation snips to make it bigger, and used a Roper-Whitney hand punch for access plate holes. Photos in the gallery...
www.apeusa.com is a great source for pumps, submersible fuel line, submersible cable, and OEM style pre-filters. (I paid $6 for the Honda pre-filter, part number 400-846 as shown in "kit 2").  McMaster-Carr offers Buna-N gasket material in 12"x12" sheets, surprisingly cheap.
Scott Costanzo
Sounds very interesting. It looks like amazing stuff. This article talks about actually installing it.
http://www.powerperformancenews.com/tech-articles/take-it-to-the-mat/
FYI, it would be VERY difficult if not impossible to position one of these in a stock tank that has baffles in it without cutting the tank. Not too many of those around anymore so it probably is a non issue.
Scott, do you have a photo, or can you make a sketch of  the baffles and hoe they are positioned in the stock tank? I seem to recall something like a pair of vertical walls running front to back with cutouts in the bottom but I have never actually seen them. Mine is a 90's replacement btw.
Scott Costanzo
Yeah, the earlier tanks are roughly divided into thirds with the baffles running front to back. Later ones had that inner vapor? tank in them and only one baffle but it is on the end with the sender/fill tube so your access is still restricted.
Google MGB tank baffles and you'll get the idea.
Quite interesting. But you could still put a mat in the chamber closest to the sender and that would probably work pretty well. Other than the big hole, there has to be some openings below the baffle to let fuel run through, so the small chamber on the right would act as a smaller tank in cornering. I think it'd work pretty well with a small rectangular pad in that area. You'd just need to figure out whether you had a baffle or not.
Scott Costanzo
There is a gap where the floor of the tank curves upward on both the front and rear of the baffle that is about an 1/8"  wide at the most and a couple of inches long.  Other than that the baffle is spot welded to the floor and the front and rear vertical walls of the tank. There is about a 3/4" gap at the top.
minorv8
I converted my carb/dizzy setup to EFi/direct fire during the long winter. This necessitated also a complete fuel system update. My car is not a MGB and has a tall tank in the trunk so my setup may not be of any reference to most of you. But, I also thought about using a Holley Hydramat when I first read about it. But the total price inc. shipping and local import fees was pretty bad. Also, my tank is stainless so magnets do not work too well for locating the mat.
So, plan B. I have a new Bosch 044 pump, generic filter sock for inlet, AN fittings, some stainless and this is what I ended with.
I fabricated a round reservoir around the pump and routed the return line there. There are some hole in the bottom of the reservoir. I saw a similar factory setup of some LS-engined GM car (very late Pontiac perhaps ?).
I used to have a filler where the pump is now fitted so I had to cut new holes into the tank. I did wash the tank, let it sit empty outside for a couple of days to get rid of any vapors and even the I water filled it before cutting the holes :-)
As for lines, all are AN6 hoses and hard lines. Overkill most likely but I wanted hard lines underneath the car and -6 size was the smallest diameter that was easily available. I welded a AN6 bung to the factory fuel rail to connect the hose.
The business end is Rover V8 with factory EFi setup (almost stock...).
had to buy it
The later RB tank I have only has a round tank like structure hanging from the top. The return line from the corner next to the fuel filler drops into the centre of it. No other baffles that I can feel with a long thin stick. Sounds like a good candidate to try the HydraMat. The tank is almost new and very clean inside and out. The sender hole is 2.5 diameter. According to the Holley literature a 3 x 8 mat will fit through a 2.15 " hole.
Can't see why I shouldn't try this out as long as the later style tank will fit in my 73 BGT.
Now to price out the mat and magnets delivered to Toronto.
One step closer
Lorne
had to buy it
Scott Costanzo
Lorne,
What do you have planned for the supply and return lines? Interested in seeing what you come up with.
Scott
Edit: corrected spelling
had to buy it
Scott
After reading and digesting Jim's excellent tutorial on fuel lines, pressures and horsepower(thanks Jim) I am going to try and use the existing supply and return lines with an inline Bosch 44 type pump. My Rover V8 is as yet not rebuilt, just a runner from a 95 Disco. When I get around to rebuilding it I may change the lines but for now I want to see how plug and play I can make the project. So far so good.
Stay tuned
Lorne
The sender opening in the MGB tank is 1.8" diameter, I just measured it on my car. (aftermarket tank, either from VB or Moss, about '93-'94. No baffles. Bottom flat measurements are 20" wide by 18" long.
That 15 x 8 cross is probably the best bet for this tank. Need to get a late sender with the pickup tube.
OK, so I ordered the mat for my car, plus a late sender, a brass float, and 25 ft each of 5/16" and 3/8" nicopp tubing, and pulled the Bosch 44 clone pump out of the battery well and stripped the old lines, canister filter and inertia switch. Pulled the old sender out and the tank is very clean and rust free from what I've seen so far. (E10 is great for drying the tank).
The mat and mounting magnets have come in. I ordered the magnets with the #6 studs, the #4 ones would probably be easier to position though.
I'm going to use 3/8" for the supply line, 5/16" for the return, and probably 1/2" for the suction. I am also mounting the MGB charcoal canister in the trunk (with the 5/8" vent line going through the floor). The tank vent fitting will be used, routed through the stock vapor separator, into the canister, and from there to the engine compartment using 1/4" nicopp (I really like that stuff for ease of use and good appearance at a fair price). There it will need something like a solenoid valve, EGR control valve or some such to vent it to the engine at speeds above idle. The return will be to the original pickup fitting.
The suction line may be a interesting. Originally the plan was to simply cut off the inside pickup tube and attach a hose to the mat. Still a reasonable plan but to reduce the chances of cavitation, a bulkhead fitting there would be a much happier solution with a 3/8" hose internally and a 1/2" hard line outside. Or some variation thereof, maybe even 1/2" hose inside. Ideally the bung would be at the low point. But, I believe the sender is attached to the internal tube, so it isn't just a matter of cutting off the tube, enlarging the hole, and installing a bulkhead fitting. It'll require some thought once more parts show up.
Now in my system that isn't the whole story because the EFI return supplies the working fluid for the intercooler. Most of that system is now plumbed, using 1/2" anodized aluminum fuel line and JIC fittings. Interestingly, the tube and 0-ring fittings used on the condenser can be converted to 45* taper fittings with a small insert. These are not directly compatible with JIC, but can be used under some conditions (not recommended with tubing connections though), so I can enlarge the lines on the suction side of the circulation pump.
Where did you order the brass float from, Jim?
