Source needed for Inner Tubes
Started by Merv, November 12, 2014, 04:23:56 PM
Merv
Does anyone have a source for inner tubes for my 205 70 15" tires on 6" wide wheels.
Tried Moss and my normal Jaguar supplier with no success.
My Dayton wheels are rated as tubeless but I have read so may bad reviews about leaks I am a bit concerned, also I currently am using inner  tubes.
Time for new tires and might as well install new wheel bands & tubes.
lars49
Merv,
A univeral tube with the nomunclature or GR-13/14/15 should work for you.
My  info says that it fits the following tires: 6.70-13, 7.00-13, C70-13, D70-13, C78-13, D78-13, 185R13, 195R13, 235/60R13, 195/70R13, 205/70R13, 195/75R13, 185/80R13, 6.40-14, 6.45-14, 6.50-14, 6.70-14, 6.95-14, 7.00-14, 7.10-14, 7.35-14, 26X8.50-14, 27X8.50-14, C60-14, D60-14, E60-14, F60-14, G60-14, C70-14, D70-14, E70-14, F70-14, C78-14, D78-14, E78-14, 175R14, 185R14, 195R14, 255/55R14, 215/60R14, 225/60R14, 235/60R14, 245/60R14, 205/65R14, 215/65R14, 195/70R14, 205/70R14, 185/75R14, 195/75R14, 205/75R14, 175/80R14, 185/80R14, 6.85-15, 25X7.50-15, C60-15, D60-15, E60-15, F60-15, C70-15, D70-15, E70-15, F70-15, C78-15, D78-15, E78-15, F78-15, 185R15, 195R15, 225/55R15, 245/50R15, 215/60R15, 225/60R15, 205/65R15, 195/70R15, 205/70R15, 185/75R15, and 195/75R15
Summit sells tthem http://www.summitracing.com/search?SortBy=BestKeywordMatch&SortOrder=Ascending&keyword=GR-13%2F14%2F15
Try your local Firestone. They supplied my dad's. Heavy duty, I believe.
Merv
Merv
Thanks everyone for your help.
Carl, my Firestone was unable or unwilling to find a source for Inner Tubes.
I did check on Summit for inner tubes and finally decided to buy the Coker Tubes even though the were almost triple  the cost of the ones Larry suggested. Choice was only made due to the Coker name. Not sure if they are any better.
Merv
kstevusa
Thanks Merve. Send more money to Tenn.  Coker is in Chattanooga.  We will take all we can get from your area.  Have a great day:-)
I guess our Firestone was more interested in procuring tubes since he bought the tires from them.
lawnvett
Hendrix wire wheel in Greensboro, NC, I know I'm late with this suggestion but thought I'd ad my 3 cents
