BRA 289
Started by Migge, July 07, 2010, 07:52:12 AM
Migge
Harrison expansion tank bracket. Found out that NORMA has a clamp with rubber and weldet bracket, perfect. Had just to make a bracket for the bracket :)
Migge
Made the footboxes, battery tray and master cylinders
Migge
Some more aluminium and oil filter bracket and footbox vents
Migge
Migge
Migge
Cheap throttle linkage
Migge
Linkage and glove box
Migge
Glove box will be mounted on upper and bottom bracket and bulkhead, so that I can remove the dash without the box
Migge
Started with the provisional cockpit panels.
blurooster
Beautiful work, I used a 5.0 ford in my TVR 2500M. My 289 is on the stand for my Cobra(dream) ERA 289 FIA kit
Migge
Migge
If you have a cheap 9 hole Motolita lookalike for years on the shelf and you don't want to buy an expensive 6 hole Motolita but you want to use the original barrel boss:
Migge
BWA
Looks real good Michael.  Your workmanship is impeccable!!
When is this work of art going to be on the road?
Byron
KBStag
Holy crap, wow.  That is stunning.
Migge
I really hope this year!
Migge
Some more pics:
- tunnel panels,
- the seat had not the right angle, too far away from the rear bulkhead, so I recovered it and weldet it new
Migge
Migge
- glovebox lid
- steering wheel adapter for the VW turn signal lever
- original Girling fluid reservoirs
- door sills
Migge
Migge
Yep...your fabrication skills just leave me gobsmacked!!
And then you go on to paying attention to the smallest detail.
What are we going to do with you?
Impressed doesn't even cut it! I love the car.
Live like you mean it.
Migge
Thanks for the complements :-)
Migge
Some more pics
Hole for dummy rivets
