turn signal switch wiring
Started by rficalora, June 27, 2010, 06:16:25 PM
Finishing up the wiring... ''76 turn signal/dimmer/flash-to-pass switch.  Wiring digram shows what looks like two power leads -- purple from the fuse box & solid blue from the headlight switch.  Info I got from MG Experience board was blue is power feed to dimmer & purple is power feed for high-beam "flash" function.  My wiring harness doesn't have a 'flash to pass' wire, just dimmer power.  So, I'm thinking the dimmer power goes to the blue wire on the swtich.  And, I can either not use the flash to pass function or run another (suitable gauge) hot wire to the purple wire to enable the flash to pass.  Sound right?
Hey Rob,
 You are absolutely correct on the wiring. The blue wire is hot with the head lamp switch on and the purple wire supplies the flash to pass feature. The only caveat is do not feed the flash to pass from an ign source. This will cause the ign to be powered when the high beams are on. Use a constant power source and fuse it at 15 amps.
Thanks Fred.  I talked with the wiring harness support guy & he recommended picking up power for the flash to pass from the "accessory 2" circuit.  That way it's constant power whenever the ignition is on but shuts off when starting.
Hi Rob, while it is a small problem it can have serious repercussions. Powering the flash to pass through the accy power will leave you with an unexpected backfeed problem. With the key off and the headlights on, if you flash to pass, the accys will get power through the headlight dimmer switch. This is a minor annoyance except that the dimmer switch won't carry that load for long and will melt. You would be better off to give it constant power. I would use the power feed to the headlight switch as it's nearby and correctly fused.
Interesting.  Thanks for that info Fred -- and it does make sense.  If I use the headlight power lead & flash to pass when headlights are on, both low & high beams would be simultaneously running off that same power lead.  Do you know how many amps the total would be?  I'm using an after market universal hot rod type harness & want to make sure the wire is gauged/fused appropriately.
Rob
Divide wattage by system voltage to get amps. So a 100 watt (may or may not be legal) bulb is going to draw something less than 10 amps.
Rob, lets say you maxed out your headlights. The baddest ones you can get are 100w high and 65w low so thats 330 watts total. Then add in your park lights, assume 5 to 10 watts per corner for another 40 watts. Thats 370 watts combined divide by 12 volts and you get roughly 31amps. I wouldn't feed that load with less than a 14 guage wire and would feel better with a 12 guage.
Fuses would be 35amp with 14 guage wire and 40 amp with 12 guage. At this level of draw you should be using relays to reduce the load on the switches.
However in the real world, high beam would be 65w x 2 and running lights at 5w x 4 for a draw of 12.5 amps. With the intermittant nature of the flash to pass feature 14 guage wire and a 20 amp fuse should work just fine.
Great.  Did some research & verified my headlights are standard H-4 50/65 watt.  I currently have my headlights wired through a relay & using a toggle switch to turn them on & off.  They are wired as below.  Sounds like all I need to do is tap into the headlight power wire (in burgandy below).  Make sense?
Yep thats perfect.
Remember if you can't resistor may capacitor.
Thanks Frank.  Big help.
If you're up for it, let's go one step further... as wired, the dimmer/flash to pass will be getting the full headlight current.  Is the diagram below what I'd need to do to avoid that?  And, is there a standard for how much current a relay draws on the switch line?  If it's low enough, I can probably eliminate the relay I'm currently using to protect the toggle switch.  It's a 20A switch so if I can, that would eliminate an unnecessary failure point.
Ok Rob, in this diagram your original relay becomes redundant. The only load that it has to carry is the dash and park lights.The headlight switch can handle that easily. You can eliminate the first relay and live happily ever after.
But if you really want to do it right, lets mount both relays as close to the headlights as possible. The radiator support bulkhead is a good choice. Ground both 30s,  86s and 87s are wired as per your diagram. Run fused battery power to the headlights black wire (previously ground) Use separate fuses for left and right headlights. Mount your third relay with the first two. Supply it's 30 and all three 85s with fused battery power (or accy power if you want the lights to turn off with the key). This third relays 87 will be power to the park and dash lights. 86 goes to your headlight switch along with the flash to pass and the dimmer power wires. The other side of the headlight switch gets grounded.
What all of this does is remove all the load carrying and hot wires from the passenger compartment as your switches now only control grounds. It also leaves you with some form of lighting if a fuse blows.
Isn't this fun?
Ok Fred, I think I get the concept - and I like the idea of getting the high current leads closer to the lights/out of the cockpit.  I have a couple of questions that will help ensure I'm following you (I've traced wiring digrams to find/fix problems, but have never messed with relays till now).
Question 1:[/U]
I've diagramed what I think you said, so 1st, did I get it right?
Making sure I understand the operation:
Flipping the toggle switch completes the 85/86 circuit in relay #1.  In this position, the relay is "energized" so 30/87 are connected providing power to tail lights, park lights, & instrument panel lights.
Dimmer Power on the dimmer/flash-to-pass switch is now also grounded which completes the 85/86 circuit in either relay #1 or relay #2 -- depending on the dimmer switch position.  The correspoinding relay's 30/87 are thus connected so either low or high beams are on -- and switch between them based on the position of the dimmer switch.
The flash-to-pass lead on the dimmer/flash-to-pass switch is also now grounded so when the flash-to-pass switch is pulled (connection made), relay #1's terminal 86 is grounded so the high-beams come on.
Question 2:[/U]
If the toggle switch is open, the flash-to-pass is not grounded so relay #1 would not energize.  Should the flash-to-pass lead on the switch go straight to ground so that function works even when headllght switch is off?
Question 3:[/U]
If I have all this right, the hot leads in my wiring harness for headlight power and dimmer power are no longer needed & should be removed/appropirately capped off.  Right?
Rob
Excellent Rob. You have grasped the concept relay relay well.
You are right the flash to pass should go to a permanent ground.
Sorry for the error, must be the Coors kicking in. I'll get the lovely Lynne to punish me apropriately.
The fuse for the park lights can be much smaller. total draw on the system will be around 3-4 amps so a 10 amp fuse would be more than enough.( the relays draw 0.2amps each, dash lights are 0.25 amps each and park bulbs are 0.5 amps each ) Max draw for the headlights is 10 amps so a 15 amp fuse for each light would work well. You could power the high / low relays from the headlamp fuses so that a blown park fuse won't leave you completely in the dark.
Yes your current power leads are unused, cap them or use them for something else. Sound system comes to mind.
See what I mean about not having any high draw hot leads inside the passenger compartment and brighter lights to boot? You also would have to blow all three fuses to lose all of your lighting.
Did you think about powering the relays through the accy or ign? That way you can't leave your lights on. You could even split it up and have full time park and keyed headlights, or full time low and keyed high and park or...... wait a minute....Coors kicking in again.
Cool.  Thanks again.  Now if I can get through surgery tomorrow (2nd one in 1 week -- $#@&!) & feel better by the weekend I can finish the last of the wiring.
By the way, what's "two strokes" refer to?
Nicely done Rob
Few people have figured that one out before.
I used to build and race go karts and got the nickname "twostroke" for taking the rules to a new level when I built engines.
Nowadays I collect old Italian scooters so DiDueColpi fit and it's cheeky enough to be fun.
Hope the surgery goes well
Hi Fred, I hope you don't mind me re-surfacing this thread seeking some more info...  I still have the single relay inside the cabin but am getting ready to make this change.  I added the hazzard switch to the diagram -- it's constant power to the hazzard flasher; other side of the flasher goes to a toggle switch; other side of the toggle ties into the 87 on the 3rd relay (provides power to park & dash lights when headlights are on).  But, looks like by doing that, the dash lights will blink with the hazzards.
To correct that, I changed the dash lights --- +12v for the dash lights comes from Accessory power (same as feeds to the 85's on all three relays); ground side of dash lights ties into the wire that runs from the headlight toggle to the dimmer [labeled "Dimmer Power" in the diagram above.  That way the circuit is completed when the headlights are on, but the dash lights aren't in the path of the hazzard flasher.  Make sense?
Last, a question about the accessory power feeding the three relay 85's...  That wire will run from the fuse box up to the front of the car.  Should I run a seperate wire for each relay or run one wire to the front & split it to feed all three relays up where they are?  Seems like it'd be better to have three seperate leads because if that wire were to short, I'd lose all lighting.  If I run seperate wires (even though that'll be a pain), I'll still have some lighting even if one were to short.
No problem Rob. Good to see you working on the car.
You should really have the hazzard on the signals not the park lights. It's very easy to hook up. Just use your powered hazzard flasher and a dual pole toggle switch. Bridge the top two poles of the switch together and connect them to the output of the hazzard flasher. The bottom poles go to the left and right outputs at the signal switch. ( I don't have the wire colours handy at the moment) With the toggle off the signals work normally, with it on, everything is tied together and all the signal lights flash.
With the lighting relays it depends on how you want to fuse them. Running three wires won't buy you anything if they are all on the same fuse. Fuse them all separately and your in business.
smelfi
Rob,
Here's a site with quite a few Automotive circuit how to's.
http://www.the12volt.com/relays/page5.asp
Steve
mgbazza
Rob, the " flash to pass" has to work independently of the lighting system. It's used as an alternative to the horn & should be wired from a permanently hot source , ie. the purple cct. so it can be used in daylight as well. Your first post said it all. The switch will direct the current directly to the high beam cct. blue/white. Barrie E
mgbazza
Rob how do you manage such neat diagrams ? Barrie E
Ok, Fred - wiring the hazards to the turn signals makes perfect sense to me.  I'd avoided that because when I asked the wiring harness support guy he said it can't be done that way -- I'm sure now, he meant "it can't be done that way using just the stuff supplied."  So, i've played with the info you've provided for the past couple of days & have come up with the following -- I think it covers all the bases.  Let me know if you see any mistakes.  Assuming I have this right, I'll need to figure out which wires that I have already run can be re-purposed to legs on this vs. where I'll need to run new wire.
Barrie, the diagrams are just done in Microsoft PowerPoint.  I'm sure there's a better tool, but it's what I knew how to use.
Two things Rob.
The dash lights will work the way that you have them wired, but it's going to be hard to isolate the grounds on all of them. And if one of them grounds out you can't turn off the headlights.
A better plan would be to power them from the 87 on the park light relay  and ground them at the dash.
The other issue is the park light switch. It's currently unfused and you have a relay anyway so lets use that.
Ground one side of the switch just like the headlight switch and run the other side to 86 on the park light relay.
This is going to give you in effect two headlight switches so we'll have to isolate the headlamp side.
Use a double pole switch (just like the hazzard switch) for the headlights.
Ground two poles and connect one of the remaining poles to the park relay and the other to the dimmer, just like before. This way the headlights will turn on the park lights but the parklights won't turn on the headlamps.
This isolation can be done with diodes as well but the switches are more reliable.
Have you thought about a dimmer for the dash lights?
That all makes sense Fred.  I've updated the diagram to reflect those changes.  I ran the dash light ground back to the ground bus rather than just grounding to the dash itself, but I'm assuming that's effectively the same.
With respect to dimmer for dash lights -- well, I'd thought about it.  I have 3 of the dash dimmer switches from '67ish (metal dash) B's.  None work & I hadn't taken the time to figure out whether there's a smaller option.  So, for now, I've simply run the dash light feed on the back of my dash to a spot where I plan to mount the switch when I find one & from there back to the dash lights.  In the example below it'd get tied inbetween the park light relay's 87 & the dash lights.  But picturing that on the diagram, I'm realizing that may mean my park lights would dim with the dash lights!  I've read about 12V DPDT relays; is that the answer here -- swap the park lights relay for a DPTD relay to isolate the dash lights side from the park lights so the dash dimmer doesn't dim park lights?  Or is there a better way?
Rob
Yep it all looks good.
No problem with the dash dimmer. It will work just fine between the 87 and the dash lights. The park lights will still get full power from 87.
Now just build yourself a nice little harness and your in business.
I like to wrap mine in black hockey tape.( I'm Canadian after all.) It sticks really well, its very flexible, it avoids that goofy zip tie look and it gives that vintage factory appearance.
Get yourself the best full compression crimpers that you can find (they look like vice grips) and step up for nylon insulated terminals not the hardware store pvc ones. Or better, non insulated ones and self sealing shrink tube.
If you aren't 100% confident in your crimps ( you should be able to pull on the terminal hard enough to break the wire) then soldering might be a better choice.
Loose poorly crimped terminals cause more problems than any thing else.
Buy a good quality wire. The higher the strand count the better. Insulation counts too, PVC is bottom of the barrel. Silicone, nylon etc. are far superior. I will often buy a wiring harness from the wreckers and strip it apart. This gets you a pretty good quality wire and gives a greater variety of colours to use.
The brits use a standard wiring colour guide based on seven base colours.
Black is for ground connections.
Green is for ign. powered accys like wipers radio etc.
White is engine ign. power.
Red is for sidelights and park lights.
Blue is headlights. a red tracer is low beam a white trace is high beam.
Purple is accys that use constant power such as the interior lights, horn etc.
Brown is main battery power, generally unfused.
The trace colours are very specific and there are lots of them. If your interested "fat bloke racing" has a complete listing.
Hope thats all helpfull
Thanks again Fred.  I must be some sort of sick-o because I'm actually having fun learning how this works!!
Now, one last question for you & everyone else... The tech support guy at the wiring harness company thinks I'm crazy for adding in all this complexity (and failure points).  He's basically saying the relays have a higher probability of going bad & causing a failure than blowing the headlight power fuse.
What do ya'll think -- remembering I have to have at least one relay because I'm using a toggle switch for my headlights instead of regular headlight switch.
