Rover Stroker option
Started by NixVegaGT, October 27, 2009, 10:50:16 AM
Nic and all, This 3.85+"stroke/oem. Rover block thing is looking like , diminishing returns? I agree with Jim, if you want the mega strokes, use the block designed for them(350), with a proven track record and much less effort. If you "must", I suggest the P76 block or aluminum deck plates with liners through them.Good Luck, roverman.
NixVegaGT
I feel ya. It's more a thought experiment than a real possibility. I'd prefer to offset grind a 4.6 crank to 3.5", or build the "short" 360 we talked about. With that one the possibility of smacking the cam with our larger base circle roller cam is a pretty real issue, I guess. I don't know how close it is in the 350 as it is with 3.85". Anybody know?
Nic ol' chum, cut to the chase! Get that "Wildcat" 4" bore block with "raised cam"-matching elevated price, TA heads, any ol' stroke you want and WOW us! Cayman account? roverman.
NixVegaGT
Until that happens-Nic., I'm "peepin" that, I-beam, 4340 billet, 2.1"x6",sbc rod from "KMJ"-thanks to Nic. Approx 1k hp. rated for $330 and only 610 grams-before I narrow it !  China-huh. Different Strokes-folks, roverman.
pcmenten
Nic, I seem to remember a Silvolite catalog where a fella could look up pistons by their bore diameter. Do you have any other sources?
Reason I ask is that I was high (only) bidder on a Rover 4.2 crank. I thought it would be pretty trick to use in my Olds engine. Obviously, I hadn't thought it through. If I do that, I'll need pistons.
If my math is right; 8.96" deck height, 1.515" throw, 5.66" rod, I need a piston set that's ~3.500" bore, with a 1.785" deck height.
nalle
I looked at summitracing's page and could not find anything with a compression distance of 1.785", but a few with less distance. Maybe some longer connecting rods to compensate, or go with custom pistons from perhaps JE or equivalent manufacturer. It is probably not going to be cheap though.
NixVegaGT
Hey Paul. I think this will be a cool mod. You'll make what... 240ish? Sweeet. Here's a link to a Silvolite page I've used a lot:
http://www.beckracing.com/silvtoc.htm
Looks like a late 70's Buick 3.2 V6 is the piston you're looking for. 1.78" comp height. Should work great. I doubt there will be any thing other that cast but you should be fine with that.
pcmenten
Brilliant! Amazing, that piston is perfect. I might have to go with Chevy rods to get a better pin fit, but it's so close that it will work fine.
Thank you.
Paul, you might want to consider the merits of a longer rod? More "burn" time, reduced "I" loads, easier on cyl. walls, cheep insurance  and fits the zillions of sbc. piston combos avail.? roverman.
pcmenten
Art, I always appreciate your excellent advice.
I'll check out the prices of the 5.85" and 6.0" Chevy rods and compare that to the cost of working up the rods I have on the shelf. I've got some 283 and 327 small journal rods (they are only slightly different). If they aren't already rebuilt on the big ends, I may opt for some custom rods. Piston selection gets easier with the 5.85" length rods.
NixVegaGT
The rod ratio is pretty nice at 1.86:1 with the stock rod, though. That's pretty good.
pcmenten
I'd prefer to use the stock rod because it would be less work and less money.  But the pin size on those Buick 3.2 pistons is .9398" and the pin size on the stock Olds rods is .875". I don't know much about boring out wrist pin bores, but I was guessing that boring the stock rod pin bores that much might not be a good idea. Would it work?
I just assumed that boring out the Chevy rod pin bores (.927") was not as risky.
I'm not crazy about the dish on that piston, 9.5cc, and I would have preferred a flat-top with notches for the valves, but I just figure I was fortunate that Nic was able to find something that was going to be close enough to work.
The 4.2 crank is costing about $80 including shipping, maybe a little more. It might need to be turned. The pistons are stock-type, so the cost of that would be a wash. So, it's just a matter of modifying a set of stock Chevy 327 rods while they get rebuilt. Not bad.
Edit; with a .030" oversize piston, displacement would be 237"/3.9L.
NixVegaGT
Ok. good point. I didn't think about the pin dia... OK so let's say you use the 5.85" (+150) SBC rod with the Chevy 2.8L V6 piston. The pin dia in the piston is only .905. Bore that out to .927 and you're good maybe.
The one I'm talking about is the #1478
Gentlemen, If  #1478 takes a floating pin, probably better to bush rod to .905" pin size?  Reaming out piston pin bores is a "precision" job or the piston becomes an ash-tray. roverman.
castlesid
Nick/Art,
You might like to read this article by a certain Mr. Iskederian which covers the issues of rod length and cam duration. intersesting, controversial?
http://www.iskycams.com/techtips.php#2005
Kevin.
NixVegaGT
I think he's correct in that you will not change the output of the engine by changing the rod length alone. Another thing I agree with him about is that an engine is setup the way it is and there are some things that are just going to be the size they are. That's true for us too. I'll get to that. I also agree about the assertion that  long rod ratios are meant for low end torque motors. The piston speed at TDC of a short rod ratio is better for that.
I did think it was funny that he started out arguing that rod ratio doesn't make a difference and then countered with a story that it does. LOL! Seriously though, I'd love to sit down and have a conversation with him and some other guys of his generation that were there when all these ideas were being formed: Crower, Edelbrock, Burt Monroe. That would be cool. I'd ask Crower why his LCAs are so wide. I do appreciate Isky's argument that the piston sitting at the bottom of the stroke is better for sustained cylinder filling but this is why it's better for low end torque.
I think he's starting out his article with hyperbole to make a counter point that you are not going to unlock secret power by changing rod ratio alone. What we build in an engine is a system of cooperating components. In our case we are pretty much limited to what Chevy guys would call impossibly small bore size to start with. SO we are limited in our ability to increase valve area. With that in mind short rod ratios are going to hamper what we have to start with. I'm talking about monetary feasibility as well as mechanical and expertise. My point is the rod ratio should work together with the other mechanical functions of an engine to be optimal. The point is, the engine he described is one way to make power. What you need to do is optimize the cam to... Wait a minute. Is he selling me a cam?! LOL.
To use his example as a point that rod ratio is an important cooperating factor. The engine he describes NEEDS more duration to MAKE power on the top end. And he's right changing the rod ratio alone without changing anything else would likely yield no benefits. With our engines, considering the bore limitations as well as the limits of our head castings we have to keep these factors in mind when considering rod length. If we had room for massive intake ports we could get away with shorter ratios as well.
The last thing to consider is engine longevity. Piston side loads and shear are factors to consider when building an engine to last. Just sayin'. In conclusion I agree with him. Rod ratios do matter but are not solely responsible for the creation of power in a 4-stroke engine.
Yes, I would one day like to know, half of what "Ed" has long since forgotten. I wish he would have opened that can-o-worms called,"wrist pin off-set". OEM.pistons, uses them almost exclusively. Aftermarket, especially forged,NO! I suspect they don't want the bother and not enough request? As I was taught, decades ago, correct off-set reduces latteral thrust on cylinder walls, reduces piston rock at turn-over and reduces "I" loads and ring flutter potential because rod and piston doesn't completly stop at top,(crank pin past tdc. while piston is not). I defer to my previous post that, not once ,did I elude to greater hp. and torque. I was expousing "some" of the merrits whilst "juggling" for a "combo" of parts to fit a particular build. I suggest a read of all of "Ed's" tech wisdom, especially of that dreaded, .842" flat tappet, maxed-out at .007"lift per deg. vs. rollers. My vote isn't cast as of yet, for oem. hyd. rollers, as I eagerly await for qty. 48 en-route. Time will tell, roverman.
Mr. T
Gang,
The 4.6 has a rod ratio just a hair north of 1.8 - what's the effective ratio with the offset?
Also, does the 4.0 have wrist-pin offset?
castlesid
Gudgeon pin offset fpr both 4.0 & 4.6 is 0.6mm.
kevin.
To put this in perspective, I believe 305" sbc/oem is 3.175mm.(.125"). Unless I was snoozin in class, I don't think off-set changes the rod ratio. I would like to see the formula an engineer would use to optimize off-set for a given build and how it changes the "I" load at turn-over,  roverman.
Mr. Isky didn't mention that silly-long rod ratio,(well over 2/1), that "Smokey" used in those 203"?, sbc's for Indy? Smokey wanted mega-long sqeeze time. Why? Slow burning combustion chambers, slow burning fuel(Methanol) and Turbo's. They ran pretty good for "Detriot wonder metal",cast iron stock blocks, once he deep-sixed the carbs. roverman.
My forged pistons have the stock 0.040" offset.
Jim, brand? For 340" sbb.? roverman.
Opps! You already said ,Venolia-right? They gave you the off-set option? roverman.
