TR6 Turbo Engine Carnage Pictures
Started by tr6turbo, June 14, 2009, 09:00:10 PM
tr6turbo
I had a number of requests to post pictures of the destruction when I got back.  Here they are.
Things could have been worse.  The head is OK except for slightly bent valves and I think I can save the piston.
mowog1
Yep.
You lightened that block somewhat!
RMO 699F
Dale, glad you could save the head...I know that was a huge concern for you....
kstevusa
Dale, at least the valve did not break!.  Could have taken out the head.  Enjoyed seeing you again.  Man you di a JAM-UP Job.  that's a good  sized hole for just a 4 cyl.
mgbreis
Dale, for those of us that weren't there, what happened? Too much boost? I really like your conversion, you did a nice job. I've always thought that the boosted 2.3 is a neat motor.
WOW!
Not what I like to see, but I guess it can happen. I hope you had fun before this block blow!
Back to the drawing board and maybe use uprated internals so this won't haunt you again.
That could all be welded..... ;-) ;-)
Hi Dale, as bad as it looks, you probably had a "whew" moment when you pulled the head -- assuming no pics of it means it came through unscathed.
tr6turbo
At the worst the head only has two bent valves.  The rods were stock and should hve been changed a long time ago.  25 pounds of boost on pump gas and a few hundred passes down the track was more then the rod could handle.  I will be building it back up with good Crower rods this time.
"That could all be welded..... ;-) ;-) "
Just mix up some JB Weld....   ;-D
302V8
Holy Cow!
Thanks for the pictures.
Pete
Dale, when Mr. Spooner gets your new engine going together make sure we get photos of that as well, should look a lot better! Glad you came on down to the meet anyway. Enjoyed meeting you!
tr6turbo
I got the TR6 back on the road tonight.  I need to get some miles on it to break in the rings before I take it back to the drag strip.  I am hoping to get it on the dyno before the end of the summer.  If i do I will post up some numbers.
Glad to hear you've got it back up & running Dale.  Looking forward to seeing the numbers.
