Fel-pro Gasket Set for 215
Started by slater, April 13, 2009, 08:29:34 PM
slater
I have a complete gasket set for a 215 (should fit 3.5).  It has been opened but everything is still in the box.  Kit part number is FS 7984 SH and includes the following gaskets
O-ring, Dist Mtg.
Fuel Pump Mounting
Head Gasket
Oil Pan Drain Plug
Oil Pan
Rocker Arm Cover
Water Outlet
Water Pump Cover
Oil Pump Cover
Oil Pump Suc. Flange
Timing Cover
Timing Cover Seal
C/Shaft Cap Seals
Intake Manifold Seal
C/Shaft Rear Brg Seal
Exhaust Manifold
First $50 gets it shipped
