1972 MG B Ford 302 conversion project for sale $12,000 for everything as-is
Started by bugguy79, September 20, 2026, 06:03:16 PM
bugguy79
1972 MG B V8 conversion project for sale:
Vehicle originally purchased in 2012 from dealer in WA and started the V8 conversion in 2013 in Eastern NC.  I drove it for a few months in it's current project completion level...extremely fun but wild ride in a 2000lb car!
It is approximately 65-70% finished with majority of the major items already taken care of.  I don't have the passion to finish it and prioritizing time with my kids.  I have $19,724 in this project, excluding the cost of the MG purchase in 2012, with parts, upgrades, labor and metal fabrication work.  I have over 50 photos from the project too.
Engine and transmission:
Ford 302 roller cam from 1994 Mustang with ~104k, cast heads.  Bottom end overhaul kit + new timing chain set.
World Class T5 transmission from 1993 Mustang Cobra Spec with 3.35 upgraded 1st gear.
Edelbrock Performer 2121 aluminum intake manifold
Edelbrock 4bbl carb 1406 w/electric choke
Through fender exhaust tube headers (Mantell Motorsports)
Aluminum radiator for 1965 Ford Mustang
Electric cooling w/185F thermostat
Billet pulleys
GM 1 wire alternator
Carter external P4070 fuel pump
MSD 6A ignition module
Flamethrower ignition coil
Moroso remote oil filter mount
Chassis and suspension:
Custom-made front 1piece independent front suspension for Ford small block oil pans + motor mounts, billet Stiletto steering rack, Wilwood disc brakes, coil-over shocks, 4-1/2 GM bolt pattern (shaves 80lbs off stock MG crossmember) (https://www.fastcarsinc.com/product/front-end-kit-standard/)
Ford 8.8 rear end with 3.27 posi from '99 Mustang shortened w/new custom 28-spline axle shafts for the MG B (Moser engineering)
Custom driveshaft (D&D Performance)
Wilwood rear Ford Mustang brakes w/red calipers
4-link custom rear suspension (Classic Conversions)
Misc. body, electrical, brakes, steering:
MG tunnel and rear cowl deck modified to fit Ford bellhousing (86-93 Mustang)
Clutch is a Nissan truck custom slave cylinder
Clutch master cylinder from 75-80 MG
Luk clutch set and pressure plate (07-042)
Brake master cylinder 70s Corvette style cast
Brake booster from 75-80 MG
Custom D shape steering shaft
Lokar emergency brake cables
Painless complete new wiring set for MG V8 conversions
Seats are 90s Mazda Miata seats reversed (also have Pontiac Fiero seats w/ new headrest speakers + new covers (Mr. Mikes http://mrmikes.com/)
Billet short shifter
Custom SS exhaust
Fuel tank centered (from 75-80 MG)
Pneumatic hood prop conversion
Radiator bar cage protection
New Autometer gauge set
Current state and what's left:
Has not ran nor started since Sep 2017 (was in storage for several years while I was stationed overseas) but garage kept 100% of it's life.
All bad fuel has been drained from the tank.
Carb was thoroughly cleaned and jets soaked
Brand new Carter P4070 fuel pump (needs installed)
MG dash and engine wire harness removed
Painless wiring and fuse block (needs installed)
Fiero seats + new upholstery (needs installed as desired)
Needs fluids changed (oil, coolant, brake fluid?)
Interior needs to be finished as desired (all old carpet and insulation has been removed)
E-brake cables need to be installed
Exhaust was cut toward the rear (need to weld or patch)
I have an entire tote of extra parts and misc. pieces.  Majority of the big MG parts have long been sold (engine + trans, seats, carpet and spare tire cover).
Asking $12,000 for everything as-is to someone who has the time to complete it.  Any questions just call or text 757-319-2822.  I can let anyone see the car too (Chesapeake VA).
