Gswest236
I tried to buy the Rover springs; they won't ship to  the US. Who else would have those springs, Rover?
I looked at the exclusion list and it didn't say US. Did you contact them? I'll see if I can find anything similar, last I looked, the US suppliers just had stock or way overkill that needed machining and a lot more expensive.
Gswest236
Ebay flagged the purchase with the comment: "Supplier does not ship to Washington"?  Google shows Crow cams equivalent springs, but they also are  from australia . Crow cam # 4823-16
I checked those and they are larger in diameter. Still looking, but Beware of a lot of vendors selling VS44 performance springs that are basically stock springs and too short. 1.58 installed height and only 70lbs pressure! Still looking, don't order until I check specs.
Lots at 1.7 height if you do the +.050 retainer. So far, the Aussie one looks like the best. Maybe you should contact him directly?
Scott, The common VS44 spring is an upgrade over stock Rover. It is perfect diameter and has over .600 until coil bind. It is only 1.58 install height so you would need these .060 shims which give you 1.64 installed, which again, perfect. It is only about 75 lbs install height and 200 lbs open which will be easy on the cam but may have valve float above 6000RPM. Here is the bad news. Anything for Rover has inflated prices, but if you shop around you may find a good price.
https://alexsparts.com/hardened-shims-1-250-x-570-x-060-sbc-f-lt1-l98-aftermarket-heads-set-of-16/
Gswest236
I'll contact the Aussie company and see what the issue is. As far as going over 6000 RPM; I'm not doing that. 3000 is probably the highest I've got it up to. If I have to pay more to get something that will work, I'm OK with that. I looked on the TWS website which shows all kinds of Springs, but didn't see anything. I may call them tomorrow as well. At the end of the day, if I can't get the right springs, I'll have to take the heads off and get them machined. But I'll give it a day or two to keep searching. Thanks for the help! I did take the oil pump pressure relief spring and plunger out. The plunger didn't want to come out but i got it out. It's brand new so no issues other than it does't have ports in the side like the one in my other kit. so, AI tells me those ports are there for a purpose. Something about metering the pressure. So I put the one with the ports back in with an Orange spring. The spring in there was black and longer.
Scott, Too long a spring is why you had high oil pressure. You won't have to take the heads off if you drill the keepers for other alternatives. You would not be changing the ID or OD of the keepers, just removing the ridge. The VS44 springs are not the Aussie springs. They are shorter and need the shims. They are the ones Moss/Rimmer and TWS sell for $320 or more. Here's a search link to see if you can beat their price.
https://rimmerbros.com/Item--i-RB7454
https://duckduckgo.com/?q=rover+v8+vs44+valve+springs&ia=web
Gswest236
The springs you listed will work with my retainers and keepers? They just need shims? When I get the keepers delivered, I'll better understand what has to be modified. I'll take them over to my local machine shop and see if they will do the work. At that point, if the mod is successful I'll have more options as you said. Not having to take the heads back off is worth the cost of new rover springs and shims. I'm leaning towards the least risky option. Thanks!
The Rimmer listing just needs the shims and simply swap springs. they are in between stock and the Aussie springs.  . You need a 7 degree retainer for a jig to drill the keepers.
This retainer is similar to yours but 7 degrees instead of 11degrees:
https://www.rockauto.com/en/moreinfo.php?pk=10211648&cc=1034738&pt=10022&jsn=740&optionchoice=0-0-0-1
My apologies Jim but I just don't understand this business about drilling out keepers. If you remove the lock then what holds the valve stem? The operation itself is going to be hard to do. Presumably you need some way to lock the two pieces in a taper so they won't pop out during the operation and being so small that will be very tricky. Then if you succeed you still need a lock. How do you propose to do that, and what shape is the lock groove in the valve stems that he has to match? It's generally way easier to cut a matching groove in the valve stem than it would be to machine the inside of the keepers to match. Even the simplest wide single groove isn't likely to match the full length of the keeper if you plan to go that way and the corners need to be matched even if they are. That's provided you find keepers with a small enough ID to match the valve stem notch in the first place. It's not something I'd want to do and I'm a Master Prototype Machinist. I sure wouldn't trust anyone else to do it. My advice is to concentrate on finding the correct spring and forget about the keepers.
I think I used PAC springs last time around, a simple search brings them up, you might try something like "Specialty Valve Springs". That opens up a whole new world.
https://www.racingsprings.com/?gad_source=1&gad_campaignid=22353416101
Jim, They would be identical to the original Buick Rover keepers to fit the Buick/Rover valves only. The lock would be the smaller 7mm diameter of the valve stem on an 11/32" valve stem. The keepers chosen are already 7mm. To drill, the retainer upside down with shims to center will hold fine. The already 7mm hole between the keepers will help guide the bit to cut the ridge off. Dave already proved it was feasible with 10 degree retainers.  Opens up a world of standard, off the shelf retainers. The problem is the Rover valves require a shorter spring and finding one with range of lift for a .500 cam without excessive pressure is rare. We are looking at all other alternatives.
So that 7mm  perfectly matches the groove dia in the stem? And the length of the keeper matches the length of the lock groove? You still need to dress the radius at both ends to match the radius in the valve groove or at least give clearance without reducing the end flat otherwise they won't seat correctly. A square corner just won't cut it even if the groove is longer than the keeper. How did Dave lock the keepers in place when he was drilling them? Just relying on the retainer to sit on top of them isn't enough to keep them from moving. Has anyone followed up to be sure he had no issues? Then do you trust Scott to do all that and get it right, or to persuade his machinist to do it? Honestly I think it's a very last resort and not a very good one at that unless you are doing it yourself and have the ability to make dead certain that every single detail is right. A dropped valve is no joke.
Sure it's a chore to sort through all the myriad of specialty spring vendors but the springs he needs are out there, that configuration really isn't anywhere near the challenge I had fitting roller springs to the Rover head. Take a look at the PAC1231X for instance. Over half an inch of lift and 350 lbs open pressure at 1.560 installed height. I've also got #26123 on the whiteboard for what it's worth and both those were beehives IIRC. Heavy oval wire and big lift on a short stack. The ones Scott needs should be a doddle by comparison. These spring vendors show catalog listings by type, height, rate, ect. Just go down the list. If one maker doesn't have it another one will. Sticking solely with Rover, SBC or other stock springs is unnecessarily short sighted in my opinion. The oval wire springs allow heavier rates in a shorter spring with more lift.
We don't want the heavier pressure with the flat tappet. We are looking everywhere. For his driving, the VS44 mild performance with the shim is probably fine. They have the Rover price markup. The Aussie ones are perfect but doesn't ship to the US. He is going to call them, it may be an EBay thing.  Unfortunately most springs in that range are 1.7 height where the +.050 retainers would be ideal but use 7 degree standard keepers. The Pontiac springs would be ideal but need a bigger diameter seat and again use the normal retainer.
Gswest236
I emailed the Aussie company and have not got a reply. Their Ebay add has Ship to: Australia. The exclusion list appears to be wrong as it would have to list every country in the world except Australia. I'm ok paying for more expensive Rover Springs and using shims if that will work. 4000RPM would probably be the highest I would run it. The rev limiter is set at 6000RPM. So, if there are springs that will work (with shims) and my  keepers and my retainers or other available retainers, I'll go that route.
Scott, that's the easy way. You reuse your retainers and keepers. The .060 shims with the Rimmers VS44 springs would be easy on the cam. About 75 lbs at 1.64 installed and 200 lbs at .500 lift vs your current springs at 120 lbs at 1.65 and 300 lbs at .500 lift.
Gswest236
I think based on my driving habits I'll be fine. Down the road if a better spring becomes available I'd consider getting them for the future. I've ordered from rimmer before so that's the way I'll go. Thanks for the help Jim and Jim!
Edit: Parts ordered!
Cool! Those springs are similar to what mild performance motors came from the factory with.
Gswest236
If I ever have the heads off again, I will get the spring seats machined down for my current springs.
