Gswest236
I tried to buy the Rover springs; they won't ship to  the US. Who else would have those springs, Rover?
I looked at the exclusion list and it didn't say US. Did you contact them? I'll see if I can find anything similar, last I looked, the US suppliers just had stock or way overkill that needed machining and a lot more expensive.
Gswest236
Ebay flagged the purchase with the comment: "Supplier does not ship to Washington"?  Google shows Crow cams equivalent springs, but they also are  from australia . Crow cam # 4823-16
I checked those and they are larger in diameter. Still looking, but Beware of a lot of vendors selling VS44 performance springs that are basically stock springs and too short. 1.58 installed height and only 70lbs pressure! Still looking, don't order until I check specs.
Lots at 1.7 height if you do the +.050 retainer. So far, the Aussie one looks like the best. Maybe you should contact him directly?
