LT heads on SBF ?
Started by ag1234, April 09, 2024, 12:03:23 PM
ag1234
Head swaps seem to be catching on.  IOW. using heads from different makes of engines. This usually means welding of the aluminum head and sometimes sectioning and welding !   What IF you could make an adapter, custom head gasket ?  Could you negate most/all welding ?  Block and allow coolant flow where needed, match bolt holes and oil feeds while sealing compression ?
        Multi-layered answer, Art.
