Electric water pump, Rover V8
Started by Roverbeam, June 09, 2021, 06:19:08 PM
Roverbeam
Hi, I'm slowly making a build plan for the engine in my garage. My plan is to make it as affordably full-race as my resources allow, without making it undrivable for weekend jaunts in the country.
I haven't torn the motor apart yet, so can anyone familiar with the stock WP picture how it could be deleted? Just a blanking plate, or remove the guts of the pump and put the old cover back on? I'm attracted to the HP savings, as well as easier small-car packaging by mounting the WP remotely. (With an electric fan, I'll just have the alternator and oil pump on the front of the engine...)
Reasonable idea, or any thoughts against?
Thanks!
-Chad
40indianss
I have a 4.6 with the intermediate cover and am considering using a pierburg electric water pump so as not to use the serpentine belt. I was thinking about gutting the old water pump also. Will keep watching your efforts as a possible solution fo my situation
turbodave
The pierburg CWA 200 with the Tecomotive controller would be my choice. Both are excellent.
waterbucket
I bought a brand new Pierburg CWA 200 water pump a couple of weeks ago for just £89 (about $125) search on ebay under "BMW electric water pump" there were two brand new genuine pumps for less than some used ones. Here is some useful info regarding them;
https://www.miataturbo.net/engine-performance-56/bmw-pierburg-electric-waterpump-controller-69420/
and from Tecomotive;
https://tecomotive.com/download/datasheets/CWA200_EN.pdf
https://tecomotive.com/download/PWMinfo_EN.pdf
turbodave
Was that a genuine Pierburg you got for $125? That's a heck of a deal!
waterbucket
Despite what some on the other forum might think I do not spend all of my time on Ebay, but I have a slowly diminishing  list of parts that I still need and in the UK it's the place to go. Health and safety regs have effectively closed down the "pick and pull" scrapyards to be replaced with on the shelf second hand parts, already cleaned with prices to match.
A Pierburg water pump was one of the things that I wanted and one day I was looking and there were two genuine pumps not Chinese copies, one with a slightly damaged power socket was £89 + £5 shipping, the other was in an auction and I got it for £99 including shipping and it included a new thermostat assembly. Despite carefull wrapping it arrived with exactly the same damage to the connecter socket!
Roverbeam
I wonder if Meziere will sell their Buick water pump backing plate separately?
For a remote pump (I've now got a Pierburg/Tecomotive combo, thanks to your recommendations), running a pair of water hoses to the holes provided seems like a neat solution. Or just cut the plate out of alum plate and drill/tap the needed holes, for that 'fabricated' vs 'store bought' look...
https://www.meziere.com/Products/Cooling-System-Accessories/Fittings-and-Plugs/WN-Fittings/WP125-INSTALL-REV-A-65.aspx?ext=.pdf
40indianss
Roverbeam can you post photos of your modifications and assembly mounted to the front cover.  I still would like to convert my 4.6 to the pierburg pump. Seems to be a less cumbersome solution
Roverbeam
Nope, it's all still a collection of parts and plans.
I did draw it though, based on the Rover cad model posted in the "pub" forum on this site. This is the stock water pump deleted, and something like the Meziere backing plate installed, to which the remote water pump's outlet will be plumbed, into the two large holes shown on the blue plate:
If it where my engine, I would build a block off plate out of 1/4 inch aluminum. Simple enough to do at home with a jigsaw and a metal blade. Rub some candle wax on your cut line and it will cut like butter.
I would then give it a single inlet  located in the center, (where the center of the impeller used to be). The contours in the timing cover will evenly distribute the coolant to the west and east sides of the block.
Live like you mean it.
Roverbeam
I wondered at using a single hole too, as I stared at the timing cover. I just figured Meziere had a good reason for their two holes.
I showed it 'blue anodized' so it would be clear which part from the Meziere link I was copying. I agree, for a simple plate, just cutting it out (and maybe sanding the edges, and maybe running an 1/8" radius router bit around the edges...) would be just fine.
Nope, Meziere has two holes as it was originally designed to fit the small block chevy.
If you are using the Pierburg pump it has one outlet and would be unnecessarily complicated to split the flow.
If you're going the router route, (I would!) use a ball mill or pointed bit and jazz it up some. Mill some lines, sign it, draw naked people.
Whatever floats your boat.
40indianss
That sounds like a simple remedy to not have to use the serpentine belt system. It also would clean up the front of the engine.  Thanks to both for a solution.  Now to get a pierburg pump and some aluminum
turbodave
Hey Chad, You may want to make some actual measurements of your block/heads instead of relying on that CAD model. My experience having measured parts of it and compared to actual blocks, is that its a representation, and not massively accurate.
Roverbeam
Oh I get that! The 'blue part' is just the (representative) outline of the cad model's water pump. It's not what I would use to get a part made from Send-Cut-Send, nor would I print and stick it to a sheet of aluminum as a cutting guide. Thanks for looking out for me though!
67Alpine
Roverbeam, how did the project turn out?  I too am planning to shoehorn a Rover 4.0 into an Alpine.  (The engine is being built at the moment)  I would love to hear more about issues encountered along the way.
Roverbeam
I'm probably not far -if any- ahead of you. I've got 95% of my engine parts shopping list complete, the block and crank are still at the machinist's, and I haven't started the chassis mods (unless you count lots of hours scheming with cad software).
I've made a deal with my better half to finish a house project before devoting shop hours to the car build. So other than things that affect purchases or future plans (tearing down, cleaning and measuring, etc), I've just been shopping and scheming. Since I give myself a limited monthly budget for things like this, the longer I wait, the nicer the parts can be...
Old P5
After many years under a dust cover I've finally decided to get the thing running again. That said I've always intended to get rid of the engine driven pump and go electric, so this thread or any like it is of interest to me. Main annoyance will be that I'll need to come up with a solution for water to the offy manifold and the return from the heater. Any advice from anybody?
The fitting on the rear of the Offy manifold is hot water out to the heater core. The other heater line is the water return to the engine.
T it into the inlet side of the water pump or into the rad if you have an unused fitting on it.
The bypass port at the thermostat housing can be blocked as the electric pump has no need for it.
Old P5
Thanks for the response. Appreciated. Given the extreme lack of space in the engine space, on reflection I've decided to just replace the standard pump for now. Curious thing though, when I removed the pump it appears that over the years the coolant has separated....  I know perceived wisdom is that this doesn't happen, but I'm seeing blueish crystals in the galleries. Anyone have a view on this and advice on getting rid of it?
Blue crystals... deposited silicates.
Avoidable by changing coolant at least every two years.
Depends how much there is... it can be removed by running a dilute acid solution, some say citric acid, some say oxalic acid.
Never tried it myself.
If there is a good radiator place near you, you might go and ask them what they use for cleaning.
Roverbeam
Since this thread started as my build conjectures, here's the beginning of a cross flow ITB intake:
The runner cores are just rough test mules in a jig I'll use when I do the lamination - I'm remaking the cores to slightly different shapes. But just getting it all mocked up has had me grinning and making the 'brrraap brrrraap' noise all afternoon. I've done marine composite and carbon work in the past, and higher-temp epoxies are getting more accessible. So, let's try some automotive parts - what could go wrong?!?
Airwreckc
That crossflow manifold looks awesome.  Can you describe the process of designing and fabricating it?  Since I am thinking of going EFI, this looks like an interesting option.  And I'm curious what you're using for the injector system and the EFI management.
The most sensible EFI for this engine is a 4bbl TBI system such as the Sniper or whatever Edelbrock is calling theirs. Just bolt it to the 4bbl intake and go. There is also a mappable distributor.
Fitting a more sophisticated engine control system can be done, (I have an '02 GM system) but is very involved and difficult to pull off and is rather pointless unless there is some reason why the 4bbl arrangement won't work for you. In my case it was to accommodate the blower and Inderlie style air intake, but that doesn't fit under the hood like the other one can, and again, requires a lot more work. My first swap was a basic 4bbl 215. The 300 is a much better choice but the simplicity principle still applies. You can always build another engine while driving your first one and there is really no good excuse for putting that off.
At the conversion stage it is generally best to limit the added features as much as possible. Every one exponentially increases the timeline and expense. The goal is to get the car back on the road with the new powerplant so that you can experience it. Slowing that down is almost never a good idea. Get it back on the road and drive it. Then make your improvements so that they can be implemented in January or February when it'd be in the garage anyway.
Roverbeam
Design: Starting with 300 heads and assuming ports enlarged about 1/16" all around, and CBR1100RR throttle bodies at the other end, I've tried to keep the flow as straight as possible by minimizing runner bends (the middle four need to wiggle a little to fit around each other) as well as align the runner angle to the intake angle in the up-down direction. I've checked the cross sections at several points to make sure the percentage change is as consistent as possible, with obviously no decelerations, just slightly varying accelerations to the airflow.
For fun I ran a runner through a free online CFD program, just to see how it looked.
How to build (Cliff notes version):
The runners are templated on their tops and sides, then the radius is just hand shaped to blend from the intake ports to the round TB's.
I'm using G10 as the flange faces, and at the top a temporary positioner made from UHMW plastic (cutting board stuff).
The runners will be laminated from a couple layers of carbon sleeve (chinese finger trap stuff - it compresses in diameter as it is pulled lengthwise) with some uni added between. Just a wet layup, no vacuum, but I'll tension the sleeves to compress and consolidate the layers. I've built kayak paddle shafts this way, and it's possible to make really light, really strong assemblies with this method.
The epoxy is a 300˚F high temp cure flavor, so it'll go into a powder coating oven and the temps manually ramped, held, and de-ramped.
The TB's will attach with silicone joiners, so the typical throttle linkages you often see with these won't work since there's too much flex (you really don't want the throttle position to change as the TB's move). I'm planning a less sexy and simple dual cable setup.
