SOLD - 300 ci buick 215
Started by Shanto, April 14, 2020, 01:16:02 PM
Shanto
i originally built this engine for my 62 volvo but it consumed coolant. i believe the culprit is a cracked cylinder liner, but have not taken apart engine yet to confirm. i went with a ls swap and now i have no need for this engine.
1964 300 heads. milled, ported, dual springs, viton seals, bronze liners. - $300
ARP head studs - $80
1964 4 barrel intake manifold. idk why but it has 3/8 helicoils in it. - $200
buick 300 cast exhaust manifolds. great condition no cracks - $200
buick 350 hei . 10mm wires - $80
rotating assembly - 300 crank, silvolite +20 305 pistons, sbc rods - $100
sleeved block with timing cover. enlarged oil ports, 5/8 pickup. and short 300 water pump probably needs 1 new liner - $100
crower 50230 cam with lifters and dual roller timing chain - $150
fabricated aluminum oil pan - $150
300 crank pulley - $50
300 thick flywheel and new hybrid organic/ceramic clutch. just resurfaced - $100
alternator setup with brackets - $50
modified starter - $50
215 4 speed bellhousing. the super rare one that works with all the good trans - $200
edelbrock 1405 carb and phenolic spacer- fresh rebuilt and modified for 3/8 studs. and fuel pressure regulator -$150
valve covers - $50
or take it all for $1200
thats about it. located in pasadena CA. willing to ship the smaller stuff, but the bigger things id prefer local pickup.
message me with any questions.
willing to negotiate. make me an offer i cant refuse!
Please elaborate on what's modified about the starter.
Shanto
its a delco 1107266.
originally for the 215 engine.
but has additional tabs welded on and new holes drilled to correctly engage the 300 flywheel.
Very cool. Thanks for the pictures.
Zack_008
I'll take the bellhousing if you're willing to ship to 97233.
Zack
tr8todd
I will take the heads for $300plus shipping costs if you're willing to ship across the country.  02330  I will send a PM with email
blue4
I would like to know if the heads are sold, if not I would like to purchase.
Thanks Bill
blue4
I am inquiring about the 300 heads are they sold?
Shanto
SOLD the entire thing yesterday. thanks guys!
