New project, mgb sbc I will need help from you guys
Started by sconley7942, November 05, 2018, 07:39:51 PM
sconley7942
I just purchased a 1980 mgb this weekend, I have an engine and transmission from a 95 firebird. I am planning on making them one. From what I read it can be done the exhaust is the part scaring me the most. This should be a fun toy when it is done I am sure I will need lots of advice alo g the way
Can we talk you out of it?
I say this primarily because your LT1/T-56 does not fit as well as other combos that are lighter, as well.  Very likely will be 250lbs heavier than my Buick 215/T-5.
What will be your use for this car when finished, Pro Street, drag car, cruiser?
sconley7942
It will be a cruiser, I have read it isn't the best swap, just so tempting because I have the drivetrain already
"so tempting because I have the drivetrain already"
Worst reason in the world to do an engine swap. Find something that fits well unless you are planning to build the car around the drivetrain.
There have been some LT swaps done, both LT1 and LT4. every one that I have seen had extensive work done to the transmission tunnel and bulkhead but I'm not convinced that all of it was necessary. In every case the builder put great value on moving the engine down and back in an attempt to maintain a pristine 50/50 weight distribution and I think in some cases they actually went too far. The aluminum LT isn't all that heavy and even stock the MG was 51/49. It just isn't that critical. So you may be able to minimize that bulkhead surgery. I think one of the big issues was the oil filter but there may be a remote adapter available. Glen Towery says that extended sessions with a hand sledge can make the T56 fit the tunnel as well. So there's that. You will have to make engine mounts and exhaust headers. Are you up for that? And are you prepared for a build time that is likely to stretch to 3-5 years if not more? A worthwhile consideration when you realize that a Rover or Buick 300 swap can be done in a day.
GTplus
Steven, I can help, I have numerous pictures of the engine in different placements in the engine bay. Jim, the oil filter isn't an issue when installing a 350 into the engine bay no matter where you place the engine in the bay, no remote required. Steven custom headers are required for installations with the engine toward the front of the bay, while hooker block huggers are a bolt on with the engine back in the bay. I have custom engine mounts and block hugger headers on my current installation. My motor also had the oil cooler setup at the oil filter mount which I retained. The engine can be installed with no or minor front cross member modifications depending on engine placement. Steven contact me directly.
