Weber Manifold wanted with carbs
Started by reblacklaf, September 16, 2018, 11:08:14 PM
reblacklaf
I am looking for one of the following used setups:
1. crossram Weber sidedraft setup with carbs and linkage
2. downdraft weber setup with carbs and linkage
3. Very rare Mickey Thompson dual quad manifold carbs and linkage not needed
I have a modified 215: bore/stroked to 302 cu, 300 crank, rover callaway heads, TA Performance Rover roller rockers, solid lifter Crowler cam, 12.25 to 1 compression with a 2x2G manifold. I currently run out of carb before I run out of cam.
Randy (OldeBuick)
You've seen John Eales' offerings?
http://johnealesroverv8.co.uk/7.html
New, rather than used. I expect he could help you with carbs.
