Introduce Yourself Here!
Started by Moderator, December 31, 2008, 06:40:41 PM
FionaMackenzie
Hello forum! I'm new here! ':D
Welcome Fiona, Jack, Aaron, and Lincoln.
Lincoln, where in Central TX?  I'm in Willis (N. of Houston).  There are a few of us in the areas around Houston, Dallas, Austin, and Waco.
Quote1967Spitfire
Clifford Kimmel
4.14.92.210
(2 posts)
03/29/2021 01:33AM
Main British Car:
New Member
Posted by: 1967Spitfire
Date: March 29, 2021 04:32AM
Hello all! New member. Thanks for the add.
I have a 1967 Triumph Spitfire that has a modified frame, a 2V 318ci V8 and automatic transmission installed with a Ford rear end. It is an exciting ride!
It needs paint and I'm looking for seats, but I love driving it!
ilace
Howdy! My name is Ilace ("Eye-less"). I live in SW Missouri and am preparing to offer my late husband's 11th TR6 for sale.  It's a '76 that he was in the middle of swapping engines (Chrysler V8?) when he died rather suddenly last summer.  He found lots on inspiration and practical info on this site and I wish he had been able to complete the project.  Watch for an ad later this month.  Thanks!
ilace Mears
blackroadking
Hi, My name is Tim, I live in Wisconsin. I've been wanting to build a V8 TR6 for most of my life but have never found the time. I am retiring from Harley-Davidson Product Development Center in July, and can't think of a better project than that to keep me busy. Looking forward to the journey!
Spitfire 350
Tim, welcome! If you can get any time away from work before beginning your retirement, the June 1-4 meet in Auburn IN should be an inspiring event. Lots of great cars, great people.
DougD
Hi Everyone. New guy on the block here. I just got my hands on a TR6 with a Ford 302.  I've wanted a TR6 for years!  I've owned 5 Jags and 2 MGs...and am a muscle car enthusiast as well. This car (and this web site) seems like a good fit :-)
My new car is in great shape and a blast to drive. I'm changing some of the PO's work to suit my own tastes but I reckon that's pretty common.
Looking forward to chatting and learning.
DD
Welcome!  I love TR6's!  Share some pics.
Shamrock
Figure I should check in and say Hello. I'm new to the site , I own a 1955 100 that came to me without a motor and transmission. I built a new frame and now ready to assemble the body back on it. I'm looking forward to all the help I'll get here to fit a small block into it and I hope I won't be to much of a pest with all the questions I'll be asking.
kstevusa
Welcome Scott,  great to have you aboard.  Many helpful people on here and glad to help.
veight
veight
Thanks Rob
Was sent this medal on a 9ct gold chain which was a nice surprise and following up a lead for some files that were auctioned a few years ago.
Gswest236
Hi, I'm new to the site and am happy to see there's a place to share the trials and tribulations of restoring and maintaining these classic British sports cars. I've owned a stock 741/2 MGBGT, a 62 AH 3000 BT7 and have just recently purchased a 741/4 BGT V8. This car was illustrated here by its original customizer,  "Wayne Rippy". I spent the last 10 years or so restoring/modifying a 81 Toyota Landcruiser HJ47 RHD Turbo Diesel. I retired and decided to get back to the British sports car neighborhood.
The BGT V8 is awesomely fast and sounds like a race car. It has the Buick 215 stroked to 266, RV8 style headers through the inner fender wells. Rover 5 speed, Ford 8 inch rear end with limited slip diff.
Ill be asking questions here knowing that experts are close by. Issues I will be addressing are: 1) Vapor lock/ float bowl percolation causing warm start problems. I've added a 1/2inch phenolic spacer on the Edelbrock 500 CFM carb; no help! Added some heat insulation around the fuel line and filter above the engine, no help. I'm getting a spare hood/bonnet louvered in a couple weeks. I know getting the heat out of that cramped engine bay after shutdown is critical. Looking on the internet I've seen people try a fuel filter that has 2 outlets/one inlet with the extra outlet for a fuel return. Don't know if that will help. Only other thing I see out there is going to fuel injection, which may be the best fix. Would love some input from the members on possible fixes.
Next,  2)  I need a seat that fits my back, as the Miata seat back has narrow bolsters that hit me mid shoulder blade; not comfy! I've seen some comments here about seats that will fit in the small cockpit; Fierro, Miata etc.
3) A/C has a leak somewhere; not a huge issue here in Washington Sate, so low priority for now.
So, far I've rebuilt the rear drum brakes (had a blown wheel cylinder), so now it at least pretends to slow down.
The front brakes are Wilwood 4 piston discs and seem OK.
Any insights the members here can provide will be immensely appreciated!
Scott
Hi Scott, and welcome!
The AC leak is probably easy.  You can get a dye that you add to the system and then shine a black light on the components - especially around connections while wearing yellow tinted glasses and the leak will glow in the black light.  If you can't get a leak detection kit with the dye, blacklist and glasses at your local auto parts place, they're available on eBay and Amazon.
Fiero seats are definitely wider than Miata seats and look good in GTs IMO.
Vapor lock is tougher.  You're doing the typical things.  It'd help to know how hot your motor runs, what the typical temperatures are where you live, how long after shutting off you have restart issues, etc.  On thing you didn't mention is your fuel bowl floats.  If set high, you can get similar symptoms.  But, you'll likely get more and better feedback on this one if you post it on the Engine section.
Welcome again!
Gswest236
Thanks Rob,
 I have the black light and glasses you mentioned and will do the leak check once it's drivable.  I've taken it on 2 drives of about 10 miles each or so in mid 80's temp. It got up to 210 degrees in stop and go traffic. Once you shut it down, it hesitates to start and the smell of fuel is evident like it's flooded. On the longer drive after insulating the engine bay fuel line and filter at the carb, and the addition of a 1/2 "  phenolic carb spacer;  the car restarted a little better  but then as I tried to pull onto the roadway it stalled and barely restarted. This was after a 15 minute shut down period. I'm going to try one of the fuel filters that has the 1/4" return line at the carb and run that to the fuel vent line that goes to the tank. Temporally vented the cap by drilling a small hole in the back of the cap. That may have no effect on the float bowl percolation, but may help. Also, I'm getting a spare hood louvered in 10 days and that should help with the percolation issue. Otherwise I see no alternative than going to fuel injection. Of course if I can get non-ethenol gas it may help as well. Naturally the tank is full, so it wont be getting better gas any time soon if its even available here.
I'm going to look at the Fiero seat option as well. I'll post my results as I go,
Thanks again.
Boxersatheart
Hello to all!
New member here that is currently in the construction stages of an MK1 BGT conversion to Ford V8!
Just got the last of the metal from BMH and Fiberglass Sebring kit!
Fast Cars front crossmember is installed, bought their under chassis headers and radiator as well.
2008 Mustang Cobra 8.8 rear with disc brakes will be narrowed as needed....
Hope to have her running in a year!
Drive train will be a 331 or 347 Ford with a T5...
Will post pics......As soon as I can get them downloaded,,,,,,,
THANKS!
Looks like you're doing it right!
Welcome to the group!
bcwelder
Hey guys great to be here 😀  I'm in Canada 🇨🇦  just bought a 1964 hillman husky for a father,son,daughter project she be fun! I have a 500hp sbc  going in it  looking for info and I think I came to the right place 😀
RCNorthernIL
Hi all,
  I have lusted after the TR6 since i first saw one back in the early 70s.  As i got older and turned into a muscle-car guy, i thought that the two were a natural fit (even though a bit tight according to some of the stories and pictures).  So, here i am.
Cheers,
Russ
kstevusa
Welcome Russ, you'll find much info and great people here!.
Welcome Steve and Russ!
Steve, enjoy the project with your kids.  My boys worked with me when building my car.  Great memories and there was lots of captive time to get to hear what's going on in their lives!
jannhall
Hello, I am the latest addition to the community. Attached is a photo of my ride.
kstevusa
Welcome Joyce,  joint us at one of our gathering.  hope you are close enough.
