Rover 4.6 Liter takeout longblocks
Started by 64turtle, December 13, 2008, 08:44:06 PM
64turtle
I have just acquired two Rover longblocks.  These are, I believe, approx. 2002 Range Rover motors that failed in the warranty period, and therefor have very low mileage.  The failure was the crank driven oil pump failing, breaking out chunks of the timing cover.  My question is, what is the best way to utilize one of these engines?  Do you rebuild it to esssentially stock configuration with the crank driven oil pump, or do you change it to an earlier style timing cover and pump?  Will that work with the existing 4.6 crank?  Since it has a crank fired ignition, can you recreate that (neither the flywheel nor any of the ignition parts came with the engines)?  Will intake manifolds intended for the 215 series and 4 barrel carbs mate up to the 4.6 liter heads, or do I need to hunt up a fuel injection system?
As you can see, I am not very familiar with this engine family, and what works with what.  Any guidance you can give me will help me decide what to do with these engines.
Thanks in advance - Stan Edwards
hoffbug
Apparently there is a mythical "intermediate" front cover that has the crank driven oil pump and provisions for a distributor.. According the Des Hammil that was the hot ticket for a retro swap..
Ive never been able to find one so I probably will end up going with a V-6 or Buick 300 front cover.
hoffbug
Intakes designed for the Buick 215 will work...
That late cover sure is an ugly mutha, and I just don't see why they did it. A drive stub to replace the distributor is much easier and I don't see where they gained anything by it. But for a retrofit an earlier cover is much more flexible and gives you the options of using a distributor or not, and several different lower oil pump housings.
Dave
Nothing mythical about the interim cover, just scarce since it was used for just a couple of years. Find a '95 Rover. Contact Jim Stuart, he's used one on a conversion. I'd just use an earlier timing cover though.
Edit: Oh yeah, if you use an interim (or later) cover on an early engine you have to machine the keyway  on the crankshaft. The pump requires a longer key.
V8Tech
I agree with Dave ... these covers are definitely available .. it's just a crank driven oil pump (which incidently is far better) as in the later 4.6 (serpentine) version but with the addition of a distributor fitment.  It means you can fit a distributor to a 4.6 as long as you change the camshaft (the 4.6 standard cam does not have a nose for the distributor drive).
The key way issue is onle apparent on short nose cranks (i.e. 215, 3.5 and early 3.9's) the 4.0 and 4.6 engines all have a long nose crankshaft with a long keyway.
The only consideration is that the front pulley (damper) from the 4.6 (GEMS) engine will not fit .. but there is a direct replacement available for about £50 ($70).
Shaun
