BOPR oil filter bases
Started by BlownMGB-V8, June 23, 2016, 04:24:53 PM
I'd suggest this thread could be made a "sticky".
I'll start this, anyone who has more info please add to it. The purpose of this thread is to show and identify all existing oil filter bases that can be used for the Rover V8, Buick 215, 300, V6 and other Buick V8 engines. I've got photos of three so I'll go first.
The first photo is of the "Metric" filter base as mounted on the Buick 340 in my '71 MGB. Note that the frame rails have been modified to accommodate a 32" wide crossflow radiater. Curtis has used one in his car by denting, and later notching his frame rail.
The second photo is the stock 215 base. With a forward enough engine position it is possible to fit the filter between the steering rack and swaybar with this mount, in which case a hood scoop or bulge is almost certainly required. The third photo shows me holding the 215 base up next to the Metric base on the engine.
The 4th photo shows a big block filter base. These are interchangeable with the small block parts. This one almost certainly came off a late 60's 400. In the 5th photo you can see that it positions the filter forward and down, likely interfering with the swaybar but there may be applications that could use it.
Here's a couple of pics from the Photo Gallery.
Metric Base (again)
My D & D Swivel filter.
Metric base, as installed on my 71 MGB GT.
After just a little hammer work, there was plenty of clearance for a PF47 filter to spin-on/off.
Later, I decided to fit a Scirocco style radiator.
I cut/patched the frame, just forward of the oil filter, to keep the radiator under hood height.
Looking at that last photo, it might be worth trying one of the big block filter bases.
This is the setup that was on my Olds 215 engine - metric base with a D&D supplied swivel adapter.
tdecell
Here's where my filter hits with the metric base. Trying to decide whether to go with the D&D swivel or notch the frame...
Blown v8
Would this Ford "swivel" filter adaptor fit ?
It may work with the right threads on bolt to motor or motor to bolt.  You would use the Ford filter recommended for that adapter.
hoffbug
It looks like the GM GN swivel adapter is discontinued.. Part #966639. Is there another source available?
This looks quite a bit different than the one posted by Graham.. I wonder where you can source those?
It was found on 4.1 Cadillac V6 also, probably junkyard only.
hoffbug
Tony, Your pic is of the "Metric" V6 cover. On Adapting the Ford swivel adapter you would also have to look at the O ring location. Ford has 3/4"-16 thread, V6 "Metric" 18mm-1.5, 215,300,340 Buick V8 is 13/16"-16.
Blown v8
Later Rover front covers,(later then 76 known in the uk as SDi ) are in fact 3/4" unf,
I'll let the pics do the talking
If you have a later front,then the Ford part is a straight fit,
Bryan, Very nice addition to this thread!
hoffbug
Bryan.. Would that also work on a later Buick V-6 cover and pump?
Blown v8
I'm sorry,but I don't know the thread on the v6 cover !
If  you could check it,and it's 3/4 unf,I couldn't see a problem,
Looking at the centre bolt of the pump,someone good with a lathe could make one with what ever thread you'd need.
Buick 3.8 "Metric" has 18mm-1.5 thread.
Greg55_99
You're missing one filter base.  Leyland P76 on the far left:
Points filter forward at an angle but brings it down farther.
Greg
jjohanski
I am resurecting this post.  What is not answered is this.   Does the Range Rover Oil pump base that Bryan Philips posted fit an earlier Rover or Buick front cover?   It appears that it might.  The pictures posted show that the Ford 90 adapter fits the oil pump base from those Rover V8s.  Pictures also show the oil pump base installed on a Rover engine.  Is the engine pictured installed in an MGB?  Will the 90 adapter from Ford clear the pulleys and front sway bar?  These questions went unanswered and unchallenged.  Anyone know?
mstemp
James,
As long as the timing cover has the oil pump in it, any oil filter base should fit. We know that the 87 Range Rover 3.5L has the oil pump still in the timing cover and that filter base takes a 3/4" -16 thread filter so the Ford adapter works. Not sure if I am understanding your question so sorry if I am being daft.
James, The older Buick and pre-76 Rover cover had 13/16" threads. The Buick V6 with Metric cover had 18mm threads. 76 and later Rover had 3/4" like the Ford. Think it was mentioned above.
This adapter nipple for pre-87 AMC/Jeep 3/4"-16 to 13/16"-16 would work with the Ford 90 degree adapter on early Buick (pre-metric)  and Rover 13/16"-16  oil pump filter base. The Metric one would have to be tapped for 91-11 Jeep 3/4"-16 for straight fitting that size both ends.
jjohanski
Thanks for the responses.  I know that the oil filter cover will fit the early front BOP Rover front covers that have an oil pump in the cover.  I also know that the 3.9 oil pump cover that positions the filter straight (or almost straight) forward has 3/4 16 threads.  I know that the Ford 90 adapter will physically fit on this oil pump cover.  What i don't know is if when the 90 degree Ford adapter is is attached and the engine is installed in an MGB, will the the filter on this adapter clear all obstrutions, i.e. pulleys, sway bar, steering rack.  lower radiator hose, etc.  It is hard to tell from the posted pictures that this may be true in an MGB.  It is not clear to me that the pictures are of an MGB, perhaps a Land Rover.  Anyway, comments and observations are always welcome. Thanks to everyone.
BTW, I had everything solved on my MGB conversion as everything was factory right down to the overdrive and SU's on the Clawfoot.
But then I decided to go with power steering and the FI and everything is morphing.  Now the car still looks very traditional but will have EPAS, AC, FI, T5, etc.  Oh well, life is short.
James, Hard to tell if Bryan's pictures are in a MGB. I know he has a very nice MGB race car and that is what he intends. PM him on the fit. EDIT: Mark has the MGB race car, Bryan has a Blown drag car. I was trying to help others with the Buick/Rover motors fit the Ford adapter as the GM one is no longer available. There is a tab sticking out I would cut off to allow it to swivel further. The earlier motors had 13/16" fittings. The Metric V6 has 18mm fittings. The adapter I show and tapping the Metric one enables the 90 degree adapter to work with those. It should work as easily as the GM one.
