T5 Transmissions that mate with the D and D Bellhousing
Started by IU8762, February 11, 2016, 08:41:56 AM
IU8762
Hello... newbie here again.
Last year I bought the D and D bellhousing, because I intended to mate a T5 to my Olds 215.  Unfortunately, I am not sure which T5 transmissions will mate to that bellhousing.  I DO know that one from a 1996 Camaro won't (now) :)
Does anyone have a list of T5 transmissions that mate with this bellhousing?
mstemp
I have no list right now but do know that GM changed to Ford style T5 around 93. I asume the holes in the D&D BH are too far apart? Ford T5 uses narrower spacing.
joe_padavano
D&D (and others) sell an adapter plate to mate the Ford pattern T5 to their 215 bellhousing.
hlhmgb
if the pattern is clearly a rectangle it is GM;  Ford is almost square as to the hole configuration.
If it is like the one on the home page of their website, that is the GM pattern. Any GM T-5 until they switched over to the Ford pattern.
http://lugnutz65chevystepside.weebly.com/uploads/6/1/0/8/6108268/2147338_orig.jpg
Beau Dirt
V8 and V6 Camaro. Early S10.
I'm running a mid 80's Camaro with an S10 tail shaft to move the shifter forward.
