Buick 215_T5
Started by mgbman, May 25, 2015, 02:18:44 PM
mgbman
With the preponderance of T-5 boxes out there now,  anyone have a good suggestion on which one to use behind the Buick 215?
I want something that is "almost" a bolt up and where I don't have to spend a lot of time/money playing around with adaptations.
I now that it depends on shifter location, but apart from that????
mgbman
 -- moved topic --
Most people like the Camaro V8 T5, bolts right up to the  215 Muncie 4 speed bellhousing. D&D have an adapter for 3 speed belhousing to Ford T5.
Like Jim said, GM  4 & 5 speed tranny bolt patterns have been the same since the late 50s. I used a a dual bolt pattern factory Buick 215 3 & 4 speed bellhousing. My '91 Camaro V8 T-5 bolted right to it with zero issues. Aftermarket Buick/Old 215 bellhousings will do the same. If staying with the stock rear end, a T-5 with a .63 overdrive makes driving on the Interstate much better. Use a GM V8 T-5.
mgbman
Much appreciated......I did have a handle on a Camaro T5 but checking the tag number, turned out to be a V6 model.
40indianss
the used ford t5  is generally less expensive, more readily available, and has the same ratios as the elusive gm v8  with d&d bellhousing plus adapter from gm to ford pattern  the trans mount pad locates on the crossmember plus it sits parallel with simple hole drilling into the crossmember to bolt the trans mount pad and the adapter allows the longer ford input shaft to fit into the pilot bushing properly   another is the shifter is vertical not at an angle and comes up in the center of the mgb opening  but if you are diehard  gm  go for it
Don, I recently heard that maybe that adapter plate can cause an interference issue with the firewall, have you seen any evidence of this?
I have. Jim Watson has the adapter with a Ford T-5. It required some extra relieving at the firewall/tunnel area. Glad that I stayed all GM.
The Mustang V8T5 has a lower first at 3.35. OD is .68. V6 has a .72 OD. Aftermarket and Ford Racing T5 has 2.95 first and .63 OD, same as Camaro T5.
40indianss
i have found no interference issue with the adapter plate  if I remember correctly it is dimensionally similar to the gm style surface on the bellhousing that a t10 or t5 would bolt to with it being slightly vertically longer to use the ford trans bolt pattern  if I recall the chev/gm is shorter/wider pattern while the ford is slightly taller/narrower  of course the mounting bolts from adapter to bellhousing surface are countersunk  so there is no interference   also with the d&d bellhousing I  ordered no clutch fork opening is present  there is no I did have an issue with the top of the trans casting hitting the trans tunnel between the rear of the heater box footwall vents and vertical sheetmetal that normally holds heater/fresh air/fan controls and/or radio  about 3/4"high x 5"wide x6"long bread pan gave plenty of clearance   maybe I was lucky in sourcing my used mustang t5 with the 2.95 first gear  I still think they are easier to find than the somewhat similar gm t5 just an opinion
You were lucky, I forgot about the 83-84 NWC Mustang T5. It did have the 2.95 first. Those are about as rare as the Camaro V8 one. I like the newer Mustang V6 T5 with the .72 OD. With the new 3.31 rear gears. I think Carl is right with the 2.95 first and switching to .73OD with  3.4-3.7 rear gears.
Near the top of the page, look for a line that starts "Go To:" and click on the words "New Topic".
QuotePS how do you start a new topic or thread?
Click on "New Topic" above the first post
N7614Y
Thanks, looked everywhere but there.
