MGB V8 Rover 4.2 engine, T5 & parts for sale
Started by richlandsilk, July 16, 2014, 06:12:02 PM
richlandsilk
have a 4.2 Rover that was recently rebuilt. New liners, std pistons. crank polished and assembled with new rings & bearings. Heads rebuilt. Rocker arm assemblies rebuilt. Crower 50228 cam with Crower lifters. Timing chain cover checked and an HVLP pump installed with the metric take off plate. New timing chain.New water pump and puleys Balancer revulcanized. Buick 215 4bbl intake with Edelbrock 1404 rejetted for the 4.2 engine. Carb heat disapaiter spacer and low rider air filter.Engine mounts and isolators. 100 amp alternator with LH mount. RV8 (large bore) headers. Bellhousing with adapter plate. Billet 23 lbs flywheel, new clutch kit. McLeod HYTOB. gearbox cross member with mount. Rebuilt Mustang (5.0) T5 with shifter control. Aluminum radiator with hoses and Spal electric fan.   Will supply correct driveshaft for the axle being used. Have over $7000.00 invested, will take $5000.00. Located in SE Michigan
