Calvin Grannis' 1974 TR6 with LS1 (project diary)
Started by 74ls1tr6, November 10, 2007, 11:32:59 AM
JShipman
Calvin,
Thanks for the info. I'm working on a 1976 TR6 and am planning to upgrade the hubs,braking system, suspension with many of the conversions you performed. Looking through the info across the history of your project, I didn't come across any significant modifications to fit the 17" wheels under your car. Did I miss significant modifications that needed to be done to accomodate the wheels?
One additional question, the "how it was done" article identifies the quick steering rack but a few pages back in this forum you had mentioned removing and going back to the original. Did you end up going back to the quick rack and did you modify to make it easier to steer at slower speeds?
74ls1tr6
Hi Jonathan,
I used 1" thick wheel adapters that would bolt up to the 4 1/2" Triumph bolt pattern. Then the adapters had 4X100 bolt pattern studs in them sticking out. I bought the adapters from Ebayer that sells high torque starters,and wheel adapters. As for modification in front was to relieve some of the upper control arm lip on front and back wishbone arms. The back has avo shocks in the coil springs. This left lots of room in the back.
This is where I bought the adapters but for a TR6 not a Spitfire!
http://www.ebay.com/itm/Triumph-Spitfire-GT6-TR7-TR8-Lotus-Alloy-Wheel-Adapters-/230620025009?pt=Vintage_Car_Truck_Parts_Accessories&vxp=mtr&hash=item35b20650b1
I still have the quick rack steering and like it for autocrossing. I'm use to it driving around town and freeway driving, so left it in the car. I still have a brand new original rack if I want to change. As for slower speeds, once the car is rolling it works fine.
Here is the latest autocross video!
http://www.youtube.com/watch?v=JMYtlJk7ak8&feature=player_embedded
Calvin
alana
You ever get #s for the weight F/R or better still the corners?
74ls1tr6
Hi Alan,
No I haven't had the 4 corners weighed out yet. It has been a good Salmon fishing season this year so far on the Sacramento river system, so haven't been around the car to much at this time. I fabricated a trolling motor bracket extention out of aluminum so that my remote steering would have more turning room on my jet sled. So now I can be anywhere in my boat and control steering, speed,and idle by a remote control box. I can multi task when we have a Salmon on a rod, instead of just driving the boat.
I will get the 4 corners done and post the results with a full tank of fuel and me in it and out.
Phil Crawford
Calvin,
I really have enjoyed looking at your post and it has really helped me along the way.  I was wondering what you did about your center discharge of the vintage aire?  I am considering putting it in the center of the dash below the gauges.  Appreciate your thoughts on the matter.
Phil Crawford
74ls1tr6
Thanks Phil Crawford, I'm glad people can use what has been posted on this site to help them along the way with their journey, to make the car they want. It sure did help me! I PMed you what I did with the vent at this time!
Below is an email I recieved from Andrew Willsheer! He has read both articles on our TR6. 1 from Curtis Jacobson on this site- britishV8.org. The 2nd article from Dom Staci in theTriumph Tribune Nov 2011 issue. Andrew wants to take a photo shoot and do a write up in the Triumph World Magazine on our TR6! I don't know what to say. but a BIG Thanks to Curtis and Dom. I kept getting these phone calls from an extra digit phone number! He stated Dom Staci , so I called Dom to find out what it was all about. I'm just a weekend garage gearhead! Wasn't expecting this.
Andrew said he was going to be at the Pomona drag strip again for photos!
Email:
Hi Calvin,
                I'm glad I had the opportunity to speak with you earlier today on the 'phone and look forward to coming up to Elk Grove in order to photograph the car for the intended feature in Triumph World magazine. At time of writing, I guess I'll have to visit one day between Monday February 18 and Wednesday the 20th. I'll contact you when I get to L.A. during the week before and try to firm up a date.
Kind regards
Andy Willsheer
epeppy
Calvin,
Congratulations on the photo shoot and write-up.  You have earned it.  I too am one of those that has spent many hours going over your excellent pictures and detailed descriptions of what you did.  Dan Masters' picture of his TR6 with the 302 in it started me down this road many years ago to modify my TR6.  Your work gave me the specific details I needed along with help from Don Watson and his rear brake caliper brackets.
I am finally starting to reassemble.  Modified the frame adding some square tubing supports and gussets, replaced rusted out sections where the rear trailing arms mounted, new T-shirt, etc.  Had the frame powder coated and just got it back last week.  Used many of Richard Good parts... suspension bushings, steering rack mounts, front/rear springs, trailing arm adjustable brackets, R200 diff and diff mounting brackets.  I tried to duplicate your high dollar Revington kit putting the shock through the rear spring.  Fabricated the brackets for the trailing arm and welded a plate in the hole at the top of the spring housing.  Don't have the adjustable shocks but hoping it will work fairly well.  You provided me the AVO shock info (open/closed dimensions) back in Aug of 2008 so I've been at this a while.
Congratulations again and thanks for the inspiration.
Congrats Curtis!!  And, the more people who see it the more new conversions there'll be.
Ed, while you have easy access would you mind sending me a close up of what the front mounting bushings look like? Mine have barely anything left so I ordered some for a 240 SX R200S diff, but what came in is easily twice the diameter of the holes.  Looking to understand if they are just sleeved bushings or if they have some sort of lip on them.  Mine look like they probably did.
74ls1tr6
Hi Ed,
I'm glad we have been a help to you and your project. Thanks for the compliment! I like some of the other support bars you installed from the trailing arm area to the t-shirt area.
FYI:
In one of you photos, where the plates have been welded to the top of the frame. When you install your seats (if you are using the original bolts holes for your TR6 seat rack) bolts, the rear outside bolt will probably hit that welded plate. Easy fix, I drilled a 1" diameter hole through the plate. This way it wouldn't lift the body floor boards up from the frame when tightening that bolt on either side. So that bolt will probably hit that plate.
I went to a 600# 1" lower spring from Richard Good in the back which helped stable out the car upon accelerating. The ride to me was better than the softer ride which I believe was 450#. Once you get your car on the road you will get the feel of what you want with the added power you have. So I hope your rear shock will do Okay for you. My AVO's are all the way stiff. I'm going to back them off some and see how it feels. My front shocks are so stiff right now but was set up for autocross. I have the some 26 adjustment or so Spax shocks up front. I had the silver gas shocks to start with and they were way too soft. I" Richard Good lowering spring up front too.
Can't wait to see your ride done in the "How it was done article section" on this site. I think the 302 + the 289 is a tamer setup than mine for daily or a weekend driver.
74ls1tr6
Hey Rob!
You may want to talk with Richard Good about those front bushings on your R200 differential. He may just have an easy fix for you or an alternative?
http://www.goodparts.com/contact.html
I have his cell if you need it?
epeppy
Calvin, thanks for seat rail bolt info. I modified some seats that came from a Kia I think. They were pretty comfortable but were just a little too wide.
I may have to go back to the original seats and mounts unless I can find some Miata seats. They seem to be the seat of choice.  I've got the 1" lowering springs from Richard on the front and rear. They are the 450#. Like you said, I'll have to see how it feels once I get it running. Might have to go to better adjustable shocks.
74ls1tr6
Ed,
 There is someone who makes a kit that uses the stock TR6 seat bolt holes that I used to bolt the early Miata seats in, if you end up going that route. I can look up in my paperwork and get the details. It is fairly easy to do with the kit. I think Danielson's website for his TR6 has a full detailed write up.
http://tr6.danielsonfamily.org/PattonMiataBrackets.htm
The kit I have is very close , but you get the idea! I did switch the seats so the recline would work. They are on the inside instead of the outside. The lever in my TR6 wouldn't clear the triangular brace at the back of the door jam on the body tub.
You can get the AVO shocks from a UK site.
v869tr6
Calvin, I was wondering how the shifter feels with the mod that you did?
74ls1tr6
Hi Ed O,
The 4" forward shifter top mount feels good. You don't even know its there. I have 6" shifter shaft on, may even shorten it tp 4" shaft. The T56 transmission is taller than the TR6 transmission, so doing a 4" would work for a more natural feel in my application.
Isn't there an option to move the T5 shifter to the front inspection plate for your application? Between the shifter relocator, the options of T5 transmissions + shifter mod top mount relocator, you should find the right feel ,and location.
Good Luck with your new project!
v869tr6
Thanks, thats good to know on the shifter, the Z32 trans on the RB25 engine has the shifter at 29" from the front of the trans and a quick measurement of the TR6 trans while still in the car was about  25".  Plus I may need to move the RB25 engine back a little from the postion of the TR6 engine. Excited about the 200 HP, should make for one crazy corner carving machine.
BobbyD75TR6
Hi Calvin...... I just wanted to say that your conversion is spectacular.....just beautiful!  A comment and a question:
The Miata seat brackets I'm now using are made by Rick Patton (http://pattonmachine.com/Miata-Brackets.htm) and work beautifully. They reuse the stock mounting holes and once installed remain bolted to the floor while each seat is then bolted to the brackets with four bolts per seat. I can remove a seat in 5 minutes or less..... same to put back in.
My big question concerns your Wilwood M/C..... it looks like it bolts to the stock servo and I'm wondering what modifications you had to make? Is there a spacer required or was the rod altered? Does the M/C require any "pre-load". I think it would make a great upgrade to any TR6 so any info would be appreciated.
Bob
74ls1tr6
Hi Bob,
Thank you for the compliment. I have used your website several times for information in research for my build. I thank you for having it up on the web for others.
The new Miata seat conversion parts for the seats look great. I think I'm using the first setup you had, which is working fine. I just had to switch the seats because of the recliner lever would hit my rocker panel. This probably was from my T56 transmission being so wide.
The installation for the Wilwood master cylinder was a direct fit on the stock booster. The connections are reversed from a stock master cylinder. On a stock master cylinder the back port is for the front brakes. The Wilwood the front port is for the front brakes. The Wilwood master cylinder comes with a spacer that takes up all the space in the bore for a longer push rod type installation. In other words the spacer fills the bore to almost flush to the piston bore. So when mated to the stock booster the only modification I did, was to take out the adjusting screw out of the booster plunger end. Then I installed a smaller headed srew to get the right adjustment and play between the booster plunger and the Wilwood master cylinder piston spacer. I used a 1.25 MC which is to large thinking that I had 4 pot calipers up front and single pot disk brake calipers in back. Also Wilwood told me that would be the right size for my application. I'm going back to a 7/8" MC soon for better braking with less effort. I also bent my brake pedal over, so lost about an inch in foot pedal ratio.
For someone to use the Wilwood MC on a stock TR6.
1)   It will bolt right up to stock booster. (Tandem Wilwood MC)
2)   Use a 7/8" MC
3)   Fix the booster screw to get the right tolerances between the booster plunger and the Wilwood spacer inside the piston (spacer is supplied from Wiwood in the box)
4)   Switch the brake lines. The front of Wilwood MC towards front of car will supply the front brakes. The stock brake MC, the back towards the driver would supply the front brakes.
5)   Need to take out brass fitting that has the safety light in it for the dash, which ties both front and back brakes together. This part is under the booster on the wing inside fender. Name?
6)   Direct connect front brakes and back brakes as their own circuit.
7)   Install a Wilwood proportionate valve into the back brake circuit to adjust back brakes in. This will insure your brakes will not lock up. So there would be an adjustment.
8)   Be very careful adjusting brakes in and testing for the first time.
9)   Anyone please chime in if you have something to add??
I saw the PM Bob,
Calvin
Med72
Calvin:
I love that 74 of yours. Can you please tell me what size the hiem joints you used are for the steering column?  I like your setup and I wanted to begin setting mine in place.  I also need the dia and length of the steering rods if possible.
74ls1tr6
Hi Art,
 Below is a list I made up for some one else that wanted the part numbers, to make the Woodward steering shaft assembly. The steering rods you ask? I would suggest getting the parts like I did, make wooden dowels to measure up everything together, then you will know the length of the shafts needed. Your car may have a different route to run the shafts than mine. You will assemble all the parts together using the 3/4" wooden dowels as steering shafts.
Hope that was understandable?
I have all the part numbers for you that
 I used. Some parts are on this site
 page.....[woodwardsteering.com]
 ng%20universal%20joints.pdf
1) UAD3-20201( Double Universal
Joint).......(.750-20) Is used between the 2
 steering shafts that you will be making. Buy 5' of
 3/4" .120 wall steel tubing. You will be making or
 have someone weld in the splined ends inside the
 tubing ends.I used 3/4" wooden dowels to mock up
 my two steering shafts. I drilled out the ends of
 the wooden dowels so that the weld in stubs would
fit in the ends.
 4) ST201A (Weld in stubs) .750-20.....For 3/4" OD
 .120 wall tube These will be welded into each end
 of both steering shafts that need to be made.
2) UA20110 ( Universal joints) .563-36 spline X
 .750-20 spline universals. These universals will
 go onto the steering shaft at the bulkhead of your
 TR6, and down on the steering rack.
2) You will need 2 stand points (Heim joint ends
 with a ball in them) that the 2 steering shafts go
 through. The two 3/4" OD shafts will go through
 one each. I installed one in the suspension tower
 of the TR6 on the drivers side. The second one was
 on the inner fender. These will keep the steering
 shafts ridgid as it is turning. I don't know what
 the part number is for these. Look down on page 4
at the bottom. (Clevis Assembly) The silver part
 only. You will need two jam nuts per = 4
 total........here is the site page...
 nion%20mechanical%20parts.pdf
 Check out the parts pages that are linked above.
 The 563-36 splines will be on the ends and all the
20 splines will be in the middle.
 I hope this helps you understand the parts that
 were used in my build and Ken Morrisons.
Check to make sure the part numbers work right
 with Woodward before ordering.
 Calvin
IaTR6
Calvin,
Thanks for the information on the steering parts (I didn't ask the question). I have been looking at the catalogs, and am curious why you did not choose the 3/4" double-D shaft? As I type this I am wondering if the answer is the 20 splines make it easier to align the u-joints?
Dennis
74ls1tr6
Hi Dennis,
 I just figured I could make my own out of 3/4" steel tube that was .120 wall thick. It was fun tig welding up the shafts. Also it was done by someone else, and it worked.
IaTR6
Thanks Calvin, your choice sounds reasonable to me.
Dennis
74ls1tr6
Dennis,
If my memory serves me right, the double D shafts were only certain lengths. I didn't see any double D weld in ends, in the Woodward book. Therefore, to get any length of shaft, the spline way is the only way to do it with Woodward products. To answer your question you had (about the double D shaft) was probably that. Cut your own shaft and weld those up is the course used because of the length increments of the double D shafts.
Calvin
The nice thing about double D is that you can cut it to length.  That's probably why fewer length choices were offered.
