Bushing spacers for LT77 remote
Started by relative4, March 19, 2017, 11:22:09 PM
relative4
I'm replacing my LT77, and when swapping the gearshift remote from the old gearbox, I found that the bushings that mount the remote to the gearbox were toast, and that three of the four spacers for them were missing.  The one spacer I have is one of the front/upper ones.  I can get bushings from Moss, and I can match the upper/front spacer at the hardware store, but can anyone tell me the length of the lower/rear spacer?  Or a domestic source would be great too.  Thanks!
relative4
Thanks for the links.  Those are for the bushings, which as I said I can get from Moss (or, obviously, a variety of other sources).  What I lack are the metal spacers that go inside the bushings.  Does anyone have dimensions for those?  In particular, the rear/lower ones for the bolts that point inward toward each other, not the front/upper ones for the bolts that point toward the engine.  Thanks!
tr8todd
Measured up a pair of each.  Got .525" and .530" on the lower shorter ones.  Got .850" and .860" on the longer upper ones. Let me know if you need ID and OD.
relative4
