A nice milestone for Brenda's GT build
Started by 74ls1tr6, March 14, 2014, 01:30:08 PM
Our GT is on all 4 wheels as of today! I just got done yesterday welding and fabricating the rear suspension attachment points. This suspension setup front and back is from Ted Lathrop at Fast Cars. Very pleased, and nice products Ted!
Here is some photo's of the GT on the ground.
I will need to relieve some turning area just behind the front tires at full lock.
The rear tires don't look like much flare is needed, but yes it is needed for suspension travel.
Looks like I will have 1 3/8" from the flattened bump stop to the tire in the rear. That should be enough room for suspension to move. These tires and wheels are the same size as on our TR6. The MG wheels are 1/2" wider is the only difference, and same size tires. The tires are 245/45/17 Yokahama S drives.
Trying to keep this project moving along at a good pace. This project started just after we go home from the Omaha meet.
kstevusa
Calvin, look great!  Guess Brenda will possibly show up in the NEW RIDE, when?  Man it looks good. SAFETY FASTER l
More photos!
Attachment points for the Panhard Bar. Extended the cargo area where the back seat was. You can also see where a square hole is cut for the top of the Panhard bar bracket, to be welded to the frame rail. The triangular bars are so that the frame rail won't bend under hard cornering.
Center link attachment point and driveshaft hoop.
Panhard bar attachment at a different angle.
Lower link attachment point. The new frame rail bracket link attachment point has been dropped down some for better tire bit.
So far everything is looking good. Next will be to fabricate a bracket on top of the driveshaft tunnel to strengthen the top link attachment point. I will be moving the e-brake from the side to this bracket on top. It's fun to move this project at a good pace!
Thanks Kelly,
It won't make it to 2014 meet, but maybe 2015 :-)
mowog1
Of course it's an 8 inch.  That's Ted's favorite for the MGB
Making good progress, Calvin!
Yes Rick, Carl is right, and you knew also it is an 8" differential.
Have come to a close of the work day on the GT. Finished fabricating the strengthening bracket for the top link area. Figured a way to install the e-brake while the bracket is welded to the tunnel, just incase for maintenance. Welded four taps with the nut welded to the back tap in two places. The e-brake will slide in from the top, the lower hole that is drilled, is for installing the pin, to hold the cables going through the body tub. Using a Lokar e-brake handle, almost looks like a TR6 e-brake handle.
You also can see some previous owner cut part of the inner body for a make shift speaker hole. I will install a speaker there, but will need to brace the area to keep the structure integrity(between the back door jam and inner wheel well).
Preform Resources
Nice fab work Calvin ! is that a black epoxy base coat on everything ?
Dave
Thanks Rob & Dave,
Dave you are right. The blasting company sprayed high build black epoxy base coat primer. They gave me the option between black or gray. I picked black because I have gray. I figured it would be easier to find the high spots when doing the  body work.
TR6-6SPD
Calvin,
The car's looking great! We need more photos of Brenda getting her hands dirty.
Question. Do you find it an issue at all of having to clean a weld area of epoxy primer, before you can actually weld. In other words, do you think it might have been better to leave it in bare metal?
Ken
Thanks for the comments Jim N,
Hi Ken,
I would be better to have bare metal, but for as long as this project will take, I was having some surface rust showing up. So it good that is there but it is a pain to clean the area before welding.
So to answer the question, If you do all welding in a short period of time, it would be better to not have the primer.
I did think of this before they sprayed the car! Went with the primer route.
Have you ever used "weld through" primer?  I saw it on one of those tv shows.
Hi Dan,
That is the question I had for the blasting shop. They said No, we don't have that primer here. So that did cross my mind at the time too.
lawnvett
I like it, a you hoping to finish it in one year?
RMO 699F
Calvin...you have done some really great work on your car....Can not wait to see the finished product!
Scott Costanzo
Calvin,
Looks great...you're making great progress!!
I heard that "weld-through" primer was a compromise. Not very good to weld through and maybe not a very good primer either. But then maybe that was just a rumor...
PJ, It is always nice to say one year, but we all know it does take longer than that. The good part about this build is that we have probably 85% of the parts already.
Scott, Is our engine in the same place as yours??
So today we thought of test fitting the ls1/T56 in the engine bay. It went right in, with grinding the front lip off the middle cross member. The engine is sitting on the rectangular bosses on sides of the block, right on the frame rail, and just in front of the front bolt holding the suspension. Of course with Teds front suspension the Camaro pan just slid passed his cross member.
Here are some photos:
Okay, This photo was some of Brenda's humor, figuring it would help to get it in there!
The modifications that were already done before attempting test fit, frame rail mod on both sides, and firewall cuts.
The water pump fittings will be taken out, and tapped for 90 degree fittings like we did on our TR6.
There is 1 1/2" between the stock firewall and the passenger head which sets back farther than the driver side.
Some more photo's to follow showing fitment!
I believe the stick shift will work just fine right there.
The engine oil pan and the steering rack are about the same distance from the ground.
A photo taken from the hatch area to show where the heads sit at the firewall. I'm really surprised that the T56 Reverse Lockout Solenoid clears in the tunnel. The T56 has plenty of room without any modifications to the tunnel. The only issue I saw was the transmission tie in cross member will be back by the frame cross member. So to use the original cross member bolt holes a unique cross member will be fabricated.
Made for an ls1, looks like it should and was meant to be in there.
Passenger side header clearance
Driver side header clearance.
Driver side.
passenger side.
I think from the rounded area of the inner wheel well panel, it can be re-formed at a 45 degree since with Teds front suspension clearance on the other side. The area right in front of the spark plugs, the first two plugs, just maybe run headers down through between the frame rail and block. Will need to look at that a little more.
Calvin, I like your idea of flattening the rounded area. Still looks tight between engine and frame. On the other hand you could just cut it out there for RV8 thru the fender headers and the hole would let some engine heat escape.
Steering shaft routing looks interesting. :)
Jim after looking at the header area, I think I will go down through the inner fender wheel wells. looks like plenty of room going that route.
As Carl noted that the steering routing looks interesting. If I go the RV8 header route, the steering shaft will be a straight run down to the rack.
Photo taken looking at the routing for the steering rack to the column firewall.
Black cap on steering rack shaft.
This photo taken inside where the steering column would be close to the firewall. It looks like a straight shot to the black plastic cap on the steering rack shaft end.
It looks good doesn't it Carl, the routing? One u-joint at both ends should do it. The only issue would be the motor mount?
