GM 10 bolt (dana 44) axle & front hubs
Started by richlandsilk, September 22, 2013, 02:47:35 PM
richlandsilk
have a GM 10 bolt axle that was gone through by Moser. They disassembled the axle, removed old bracketry, cut and narrowed the housing, added new spring perches. Cut and replined the axles, checked ring & pinion & posi, installed with new bearings & seals. It is a 3.44:1 with posi. bolt pattern is 5 x 4 3/4" (MGC & chevy) To go with the axle I have a set of MGC front hubs (bolt on wheels) These are quite rare. The axle does not have any brakes, so can be set up with drum or disc. Can load on a pallet and ship. Located in SE Michigan. $2200.00 OBO. PM if interested.
