Getting down to the wire (ing)
Started by smelfi, March 16, 2013, 11:27:21 AM
smelfi
I've been at this build for about four years now. Finally down to the wiring plus miscellaneous small stuff. If (big if) I can stay on pace I might have it on the road in a few months.
Items I've attended to over the past couple of months are;
Cleaned the dash, used some vinyl repair on it to fix a few cracks and nicks, fabricated and installed toggle switch mount plates to fit where the stock switches were located, temporarily installed the gauges and switches.
Installed the radiator, radiator fan and upper radiator hose. Haven't done the bottom hose yet – need to sort through hoses at an auto part store in order to find 1 ¾ hose(s) with a 90 degree bend and a 30 degree bend.
Discovered that the 45 degree spark plug boots on my plug wires need to be replaced with 90 degree boots – one is too close to the steering knuckle and one is touching a header pipe - I have the 90's but not installed yet.
Mounted the ignition box, starter solenoid, starter, alternator and gauge sending units.
Installed the battery, cables, and battery disconnect switch.
Installed ¼ inch carb spacer – the front of the air cleaner clears the closed hood by 3/16 of an inch.
Mounted the Advance Auto wire panel and routed all the wires that go to the engine bay and front of the car.
Installed the headlight and front turn lights.
Cleaned, wire brushed, sanded and painted the trunk.
Searched several times the attached garage where the MG is, the detached garage, and the pole barn for my backup lights. If any of you know where I put them please let me know.
Here's the engine bay a couple of months ago and yesterday.
kstevusa
Looks Great Steve,  don't we just love Ford Blue
Looks awesome Steve!  This is the exciting part where you're itching to get it on the road!
Congrats on a job well done.
......should be all downhill from here!
billymgb1000
steve just wait till you get her on the road all these last minute details will be forgotten and you wont be able to stop smiling good luck and enjoy p.s. nice job
