Question, Alternator Wiring
Started by tr6turbo, January 15, 2013, 09:39:59 PM
tr6turbo
I am using a Ford G3 alternator .One of the wires going to the alternator is hot in run only.  This is the wire that has the warning light if you run one.  If you do not use a warning light do you have to put a resistor in it's place?
DC Townsend
On a 3G, the short answer is, yes, you need to run a resistor - whether you use a warning light or not, With the lamp, the resistor is run in parallel to the lamp circuit so, in the event the lamp burns out, the circuit will still have the proper resistance. Attached is the wiring diagram. You can get the resistors at any Radio Shack type store.
tr6turbo
This was kind of a loaded question.  Does anyone know why we need the resistor?  I have been running without a resistor or warning light for more then 10 years and have not had any problems.
It was to switch on the field circuitry originally I think, or to switch off the sense wire circuit which can drain the battery, but with the advent of 1 wire alternators they've learned to do without it and have incorporated this feature into most regulators. Earlier Japanese alternators are a notable exception (not sure about the most recent ones) where a relay is used in the circuitry to the sense wire to disconnect it when the key is off.
DC Townsend
I think Jim is right on the field circuit switch. And to come clean on this, when I've used a 3G, I've run them both with and without the resistor circuit without any noticeable difference. That said, I've been running 1-wire unit for the past few years making the use of a resistor, moot. But my answer to the posters question still stands - the accepted way (not the only way) to wire the 3G is with the parallel resistor circuit.
tr6turbo
David,  I agree that it switches on the field circuit.  One thing I do notice is that if I let the ignition on in run (engine not running) for awhile the alternator gets warm, not hot and the battery drains.  Does that happen in cars with the resistor?  Does the alternator use the difference in sence voltage and the run voltage when using a resistor to some how stop the voltage drain while the switch is in run and the engine is not running.  I guess I need to try it and see.
Thanks for the comments.
