GM 10 bolt axle
Started by richlandsilk, January 06, 2013, 08:06:58 PM
richlandsilk
Have a 10 bolt axle that has been modified by Moser. Engineering. The housing and axles were narrowed. They checked over the gears (3.42:1) and the posi. The old brackets removed and new spring perches installed. assembed with new bearings, seals, etc. Do not have brakes but can be used with stock GM drum brakes or disc brakes.  The axles are set up for the Chevy bolt pattern, but can be changed to the MGB bolt pattern if desired.
Robert J
mstemp
Tom,
10 Bolt still available?
Asking price?
Whatr POSI?
Width?
Mike
