Wanted: Land Rover Heads, Oil Pan & Other 215 v8 Engine stuff
Started by dbizak, September 24, 2012, 02:54:44 PM
dbizak
Looking for:
1) Land Rover Heads on a 215 V8.  ERC 0216 or HRC 2210.
2) Oil pan for same engine or for a Buick 215 V8 3.5L.
3) Oil pick up for applications above.
4) Also looking for new cam, pistons (probabably +30, 10.25:1 compression), and valve springs.
Recommend you use the V6 pickup which is 5/8" diameter. Drill the block to match.
MGB-FV8
You should contact Jim Stuart (personal message), he has some of that stuff and also Ed Chin has some Rover parts.
JHerscher
I have an oil pan from a Buick 215 if you still need it. Cheap!
