Wiper motor
Started by mgbrv8, July 02, 2012, 02:17:50 PM
mgbrv8
Are there any wiped motor modifications out there ??
Dave
kerbau53
This is in an MGB. I can't remember who the vendor is and a quick search didn't come up with anything. Search "hot rod windshield wipers", fair bit of choice.
burner1
That's mine. Here is a link to the maker:
http://www.spwkits.com/main.php
They are probably the most comon aftermarket at the hot rod shows. I am putting a set in the Pantera too. If you look at the first photo Goeff posted, you can see I used the external assembly inside as well. It had the proper angle to tighten it all down. Mg wippers bolted right up.
Gary
What feature you like to add?
There are aftermarket electronic intermittent wiper modules that work with the stock wiper motor... I recall that JC Whitney used to advertise one.
I thought the wiper motor and the fuel level sender were the only Lucas parts left on my car, but now I've discovered Lucas' name on the back-up lights and I'm fixing to put Lucas fuel injectors on my engine.
donfaber
Sounds like you are installing Rover EFI? Have you posted details of that conversion yet? where did you get HW? Thanks
burner1
The part I like, besides the options such as intermitant, push button switch for spray, small stuff....is the fact the new assembly has a strong modern motor.
