MegaSquirt-III EMS Latest Upgrade
Started by NCtim, April 20, 2012, 05:53:11 PM
NCtim
Hey guys,
Will this run my FI and coil pack ignition? If this is the one I want, I really want to outbid these guys within reason.
NCtim
Tim, MS3 will run COP or coil packs if you use logic level coils. Otherwise you need coil drivers. DIYautotune sells a 4 coil driver for about 90 bucks so you'd need 2 of them. There's more stuff coming out all the time.
NCtim
Thanks Jim,
Will I need those with the GEMS system? I'm planning my build to be similar to Evan Amaya's engine with the mods he's made. He got rid of his distributor and is using the original ignition from the '96 Rover.
http://rebornco.com/mgbv8/newmgbv8.htm
Tim
