Overdrive
Started by Rolly77MGB, March 31, 2011, 07:31:37 PM
Rolly77MGB
I am going to California tomorrow to pick up the 77 MGB I won on ebay.  I'm told the O/D does not work.  Any simple way to check O/D electrics for problems?  All ideas appreciated.
Hi Richard,
There are probably folks here who can answer your question, but you'll likely get a quicker response on questions related to stock MG stuff at the MG Experience board (http://www.mgexperience.net/phorum/list.php?1).  This site caters to folks doing engine swaps (V8, V6, turbo'd I4, etc.) into British cars.
Good luck with it.
Rob
Rolly77MGB
Thanks, Rob.  I plan to stuff a 302 into this car hence my joining.  In the meantime I'd like to enjoy it as it is today.  BTW, your car is super - just watched the video - very impressive.
Where in California?
Richard, you can run a jumper wire directly to the OD solenoid from the battery and if the mechanicals and hydraulics are in order it should kick in. If not a fluid change and cleaning the filter screen may do the trick. Internally the OD is a simple device. I once re-staked one or more of the spring pins and had a good repair. Still working today.
Rolly77MGB
Thanks for the responses, folks.  Picked the car up in Pollock Pines last Friday and drove it to Winnemucca, NV without incident - also without lights of any kind!  The wiring is a mess and I may be better off getting a new wiring harness.  JB, I will try your tips.  Thanks again.
If the wiring is a mess you'd do well to rewire.  Check www.advanceautowire.com
speed6
Or use a streetrod harness from Painless Wiring or other vendor.  Don't laugh, but Streetrodder Magazine is a great source for vendors on conversion parts.
Chad in Tulsa
