Spitty's new dash
Started by tbush, November 20, 2010, 03:37:20 PM
tbush
Here is the new dash for my Spitfire project.
The instrument cluster is from a '91 Cavalier. I am using it to be fully compatible with the ECU I am using. Turn signal indicators, shift light, and cruise light were added into the cluster.The headlight switch and hazard switch are from an early 90's Saab. I need to get new knobs for the panel dimmer and the wiper switch. To the left of the head light switch is a rocker switch for the driving lights. I put a Pioneer CD deck in the dash. The lights under the heater controls are the idiot lights, including a "service engine" lamp.
The wood is the original dash with new birch veneer and Helmsman spar varnish.
motek
Very nice. I used to have a 1985 SAAB and the switches had a good firm feel.
George
socorob
I used the saab headlight and emergency flashers in my V6 alpine, they work well. I think they have a modern look to them, an i used a winshield wiper/squirter switch from an oldr ford truck, i tried to go multifunction on everything i could to free up some of the limited dash space that was available. The only problem I have is the light in the headlight switch doesnt light up when the headlights are on. Do you know if the bulbs can be changed in them easily?
tbush
Robbie, if it's the round switch the bulb is in the back between the terminals. Just put a screw driver in the slot and give it a half twist.
-Tim
