Radiator problems.
Started by MGV, September 18, 2010, 11:14:57 AM
MGV
I order a new radiator is a little bit taller than the original.
The bottom exit is under the anti-sway bar.
Do this will be a problem? Looks like is to low compare with the water pump (3.4L chevy).
Can I just use a radiator from a 1976 MGB? What is the inlet & outlet size for this radiator.
The 3.4L that I have the inlet/outlet are 1 1/4 inches.
What will happen if I remove the anti-sway bar?
MGV
Problem solved. The radiator is fine but needed a 16 inch fan 2150CFM abd a 185 degrees thermostat.
