Midget rearend
Started by Argatoga, May 05, 2010, 10:34:59 AM
Argatoga
I'm looking for a sturdy rear end for my ~175hp Midget swap. I'd rather not build something elaborate. I've read here about using a Monza axel, but the housing looks too big (I have a 1500 lowered by an inch). Any recommendations for an easy swap?
When selecting a rear axle I usualy look at several criteria. Torque capability, ratio availability, brake compatability, drum or disc diameter, and lug pattern.
There have been several rear axles used in Spridget swaps. For your horsepower range I'd say either the Monza or the RX7 axle would be a good fit. I know the housing on the Monza looks large, but it's basically a standard GM 10 bolt unit that has a lot of ratios available for it as well as posi units. As a budget piece it's hard to beat for those reasons as well as the added benefit that the lug pattern is the same as the original axle and the rear drums clear 13" wheels just fine. Rear brake cylinder size is compatable with the stock master cylinder as well.
You could also use a Mustang II unit but the lug pattern is different there. All three mentioned were originally used with 13" wheels and small V8s or rotaries and will handle that level of power and torque.
There's really quite a bit of room under a Midget rear, the most limiting factor would be the length of the pinion area as the bulkhead is fairly close on the front side. I used a Monza rear on my 73 with 1500 rear springs and 1" lowering blocks and there's plenty of clearance, should be the same with your car.
Argatoga
It looks like Frontline is developing a 5 link rear end. In light of this I'd rather go a cheaper route for the time being. Has anyone here have experience with the Peter May, Frontline, and Magic Midget half shafts? What would be the best material? I'm seeing EN40B, EN24, and chromalloy. The Magic Midget EN40B ones are $180 each, while the Frontline EN40B shafts are twice that. Any idea of why one would cost more than the other?
Graham, for the most information on high strength axles for the Midget rear I'd suggest you post a question on the motorsports forum of the MG Experience site http://www.mgexperience.net/ or the Sprite/Midget forum on the MG Enthusiasts site http://www2.mgcars.org.uk/cgi-bin/gen5?runprog=mgbbs  There are a lot of guys on both sites who race Spridgets and have experience with those axles etc.
Hey Graham,
Back in the day (early 80s) I built a 65 midget with a full on Datsun 240Z engine. It was bored and stroked to 3.1L and ran triple webers. After breaking 3 of the strongest midget diffys available I found that a tr4 diffy was almost a direct fit. The width is good and I dont recall any major mods to fit it in. It took all the abuse that an eighteen year old road hero could throw at it.
Hope that helps
