Buick/Rover Schematics?
Started by mindseye, January 12, 2010, 11:38:16 PM
mindseye
Does anyone have the drawings/schematics of complete breakdown of a buick/Rover 215?....appreciated
Simon Austin
I've got a copy of the Rover Engine Overhaul Manual in a PDF.  Is that what you're after?  817KB so it should transmit fine.
mindseye
Thanx Simon...I sent you a PM....P.S. i almost forgot send me some pics of your car....might be your way one of these days since we are so close
Simon Austin
Just sent the PDF, John.  If you haven't seen the car yet, it's on the photo gallery here.  I can always send more.
mindseye
Very nice, I like the body curves ...very exotic...looks like Miata seats?....are they as much trouble to install as I have been reading?...I see you got the extreme top filter, did you need the scoop for it to clear?....I got the same engine set up but want to keep my stock hood
Simon Austin
Thanks John.  Miata seats are correct.  Not overly difficult to install, just time-consuming.  I've got some instructions I can send you if you like.
The scoop helps to clear the X-treme top as it's "domed" quite high.  I've got the "trident" hold-down nut as well which sticks up quite a bit.  One could use a regular nut which would help.  The problem with the Edlebrock intake is it's height and the stock mounts.  If you've got the same set-up, you'd be hard-pressed to get this to fit under the stock hood.
Here's a photo taken straight-on to the car with the hood open showing the "domed" X-treme filter and hold-down nut.  Next time I get to the car (parked off-site), I'll get a photo with the hood closed to show you how it looks.
