strange vacuum reading
Started by Roverboy, December 17, 2009, 10:38:38 PM
Roverboy
Hi,
Being old skol, I rely heavely on a vacuum gauge for my diagnostic and post build analysis.  However I came upon a strange reading after one of my mild 4.0 rebuilds.
Everything looks good except that when I blip the engine, I expect to see the gauge run towards zero, then back up to bout 25 when I release and back to 20 or so (steady).  However, with this one, when I blip , it will just go down to about 15, then back to zero (while holding rev) and then to 25 after the release and a steady 20 at idle.
The build is a rather standard;
rebored and sleeved to spec a 4.0, crank polished, main cap to 2thou as per specs, rings hand lapped, stock rods/piston, block decked at 3 thou and heads planed with composite head gasket, heads cleaned and polished new stock valves, springs etc etc..  Custom grind on cam ( low rpm torque), HEI, edelbrock, Holley 470 CFM, hedders coated and wrapped.
Onboard diagnostics;
wideband, water temp, oil pressure, vacuum, EGT (single side) , tack  (all autometer sport comp)
The only thing that I think could explain this is that I have too much back pressure..
Please chime in
Sounds like you have a bog. I'd check the carb for correct accel shot and tip-in.
