Oil Viscosity ?
Started by kstevusa, September 04, 2009, 02:38:47 PM
kstevusa
I just change the oil in my Old 1995 chev. truck.  I had 2 qts of 20-50W & 2 qts of 10-30w.  Mixed both of them together in the crankcase,  What nominal weight oil do I now have?  15-40W?   I always wondered how the different viscosities mixed.   Any answers?  Just couldn't dispose of the 20-50w. w/o using it.  Leftover from the 4 cyl.
kstevusa
WHOW!                 Less than overwhelmed by the response of our knowledgeable ?  members.     any ideas?
SAFETY FASTER!
Hi Kelly,
I did an internet search on mixing viscosity and there are a lot of different opinions.  I didn't find anything definite, but maybe you can with a little time spent.
kstevusa
Thanks for reply and interest Dan.   The Pub looked to be down on posts and I thought maybe this would generate some traffic.  I suspect  the final product is a mixture of the properties of  2 viscosities.  the final results are not a major concern since they are all ready completed.  Appears the oil pressure is up a little  when cold,  but drops to normal under operating conditions.  this seems to indicated the oil this thicker at first than the 5-30W. used earlier, but not up to the 20-50W  .
Thanks and have a great day!
I've heard that oil can be thinned with a couple of tablespoons of Dickle.......however, the final concoction has explosive qualities, so should not be used regularly in an FoMoCo engine.
            Hope it gets you safely to Pete's this weekend.
kstevusa
Thanks for well wishes.  Have a safe trip to The Glen.   Dickel has lubricating  quality, but does not mix too well with petroleum. It makes the tongue loose, but the tale tight.  Plan to carry 2 fresh watermelons  pick this AM.  may plug them and add PGA. Should be a whale of a GOOD TIME!
