For Sale: chassis/suspension tabs, brackets, and mounts
Started by Moderator, March 25, 2025, 07:33:01 PM
I'm keen to clear off a few shelves in my garage.
Buy just what you want. Prices below.. I'll check postage options. I'll expect you to cover actual USPS mailing cost. No handling fee, of course..
This style of mount is typically used for connecting 3-link or 4-link suspension links to a frame. Maybe you have a different use for them. They're plenty robust!
Ballistic Fabrication brand. 3/16" thick, nominally 2.0" spacing but actually measure 2.20", 1/2" holes.
$5 each (new)
Typically used for connection to rear axle, after being trimmed to size of course.
0.176" thick, 1/2" hole
$4 each (new)
Aren't these cute? Could work for shock absorber to axle, or  anything with Heim joints such as a Panhard rod.
$3 each
Notice that there are 2 rights and 1 left... or 2 lefts and 1 right depending on application.
3/16" steel. Holes sized for metric bolts, 2x 12mm and 1x 8mm.
$2 each (new condition)
I really like these! They're what Freightliner and Western Star use to mount cab-suspension shock absorbers to the cab.
$20/pair (gently used... but I've removed the paint so they're ready for you to work with!)
I've used these as engine mounts (as have others including Ted Lathrop I think) and also as transmission mounts.
Volvo and Freightliner have both used these to mount radiators. (This is the actual Freightliner OEM version.)
Sized for a 1/2" bolt and a 1.25" diameter mounting hole in 1/8" thick bracket.
$6 each (new condition)
Let me know if you want more specific measurements
