Toyota W50 5-spd ODTrans w/ custom 215 Bellhousing MGB $650
Started by cdf999, March 22, 2023, 06:47:50 PM
cdf999
This is a Toyota Celica W-50 5spd (w/ OD - 0.83 I think) mated to a modified bellhousing that mates to a GM 215 block.  What u see is what u get, and I don't have a lot of info about this setup other than it appears to bolt up to the 215, and I have to assume you use a toyota disc with a GM pressure plate.  You will need to pick this up in midtown Atlanta... probably not shippable.  I only want $650 for the entire setup - and that's a deal.  PM me if interested.  Thanks !!
AVAman
Hello,
I may be interested in purchasing.  However, I would need measurement from bellhousing flange to center of shifter. Replacing 2-speed dual-path auto trans in my 62 buick skylark.
Tony Andrews - 410.490.0427 - THEherbert61@gmail.com
