Robert Janca's 1975 MGB 302 V8 Project
Started by Robert J, December 03, 2011, 06:52:47 PM
Robert J
Owner: Robert Janca
City: Oakland, CA
Car Model:  1975 MGB
Engine: Ford 331 stroker engine
 9-1 compression. Pistons are made bye JE. Rods are Eagle h-beam. 4340 steel crank the rotating assembly is all 0 balanced.  The whole engine was zero  balanced together. The cam is a roller xfi cam 575 lift cam was also degreed. The heads are (afr)air flow research 205 outlaw heads and the roller rockers are comp cam magnums. The engine also has a girdle on it with arp bolts.
Cooling: TBD
Exhaust: TBD
Transmission: Freshly rebuilt WC T-5
Rear Axle: Stock to start with.  Going with a Ford 8.8.
Front Suspension - Pete Mantell's crossmember kit.  Completely new suspension and brakes. Fully adjustable upgraded Armstrong shock absorbers, polyurethene bushings and the 3/4" anti-swaybar.  I
Rear Susp.: TBD
Brakes: Stock right now.  Future; TBD
(master)
(front)
(rear)
Wheels/Tires:  16" Enkei honeycomb mags.
Body Mods: Rubber bumpers removed. Flexible air dam (not pictured) and fiberglass tail installed with chrome grille.
Interior: Miata leather seats.  3" diameter Roll bar.
Electrical: Painless wiring kit
