ABS Brakes anyone?
Started by BlownMGB-V8, October 18, 2026, 09:06:32 AM
I ran across the Delta ABS Motorsport ABS package yesterday, apparently a standalone ABS system suitable for top level competition use and adaptable to pretty much any vehicle. It should be with a package price of nearly $5K but it spurs thoughts of less expensive implementations.
Obviously the two critical components are first and foremost the controller and secondly the solenoid block. Having formerly disassembled an ABS pump assembly it seems a fairly simple matter to come up with an alternative, they cite a higher volume as being their pump's advantage. Frequently the pump is combined with the solenoids but Rover and some others have used separate pieces. It is probably worth checking to see if they will sell their controller separately.
It uses a couple of sensors aside from the individual wheel sensors which they state should be hall effect and at least 40 tooth. Should not be too hard to set up.
I expect there are any number of alternatives out there once we start looking.
Dan B
Bosch 5.3 used a most manufacturers starting in the late 90's, including domestic, euro and Japanese, according to Grok.
ATE/Teves MK60 used on BMW M3 is a little more adaptable but more expensive, the SI says.
#2
Been looking at Rover parts since I have the pump assembly already. In the mid 90's they used a system that had a separate pump and then a control assembly which also has a smaller pump for return flow and the reservoir, the M/C and a link for the pedal. With the late bedal box I think it might fit the MGB. Big reservoir, it holds about a quart but that's required due to the nitrogen charged pressure vessel on the pump assembly. It's recommended to push the brake pedal 30-40 times with the key off before checking the fluid level. This may not all be completely accurate as there were a number of variations in the bits used.
A question that has come up is how the controller acts on ice or when it thinks there is ice. Apparently it can be fooled into stopping very slowly under some conditions. The Delta controller does not have this "feature" as it is a race oriented system which they claim is suitable for competitive FIA applications, however I suspect it might be just a somewhat less sophisticated controller, in the fashion of aftermarket engine controllers and such.
Dan B
On the rover, is that the Bosch 5.3?  It seems to me it was one of the makes Grok mentioned, as well as MGF
Much research has been accomplished, some parts ordered, and a plan established. Quite a lot of research and figgerin' really, almost like an engineering project.
So it became pretty obvious early on that the late pedal box would have to be used to allow room for parts, and the balance bar had to go. I'll find another use for the big walnut knob under the dash.
Next thing I found out, my Jag rear brakes and Outlaw front calipers are in pretty close to perfect balance, around a 64/36 split which I can probably live with as an interim configuration between stages. Next is that I will only have about 12" between the pedal bracket and one of my header tubes, making part selection a bit difficult.
However, the Wabsco pump/accumulator unit is very versatile and will work with numerous hydroboost units, leaving the ABS and sensor package to be added later as a second stage. Drilling a pattern of holes in the inner face of each of the brake rotors can provide the required wheel sensor arrangement.
Those hydroboost units? They work well with several solenoid/controller packages, some of which are self contained, leaving only the sensors themselves. Fortunately the right selection of units means the main pump and the ABS can be located almost anywhere.
So selection of the hydroboost and MC are kinda critical and almost killed the project. But as it turns out, the Germans used a nicely compact hydroboost in the BMW e23 7 series, one of which had the mounting flange about 1/4 of the way along the bore, and in combination with the MC gave about an 11 inch overall length so it ought to fit. Also from BMW was the ABS, a Mk60 Teves unit, but not just any Mk60, oh no. It had to be special and hard to get naturally. Still working on that one.
All of these parts *can* be extremely expensive but don't have to be. I prefer not to pay the BMW tax myself, so I've managed to cut costs pretty well so far. In the end I don't think total expenses will hit the 1k mark, but they won't be all that far below it.
And what do we get for all that then? Well initially brakes that have a light pedal and work very very well. After that, anti-lock suitable for a race track if I get the right ABS unit. At the very least excellent street manners.
I'll take some photos once parts start to arrive.
Well, have fun.
We have survived a very long time without ABS.  We know how to threshold brake. Early ABS was not so good. I can out-brake those.  In fact, I have the ABS on my 2000 Silverado disabled.
I am aware. I am pretty competent at it myself, in fact I'd even venture to say I've had more practice at it than you have Carl, considering you never use your brakes  :o . What I can't do is threshold brake each tire on it's own independently and modern ABS can do that, so neither of us have much chance of beating a really competent system. Some are better than others. So far, the system on my Alfa has been flawless and it's made a believer of me. That is one fast car. I have yet to exceed it's limits even after Townsend this year if that tells you anything. Pete was in my way  ;D  .
There are different levels too. For instance, the Mk60 comes in different flavors. The mundane one starts to freak out over perceived ice at a slippage rate just over 5% where the one I'm looking for remains stable up to about 15%. That's a big difference which mostly relates to being suitable for track use or not.
But even without the ABS something had to be done. Pedal pressure with a dual MC/balance bar system is way too high to be safe. You went to a dual diaphragm vacuum booster, I'm going to a hydroboost. The ABS is just one more added component. Plus the sensors of course. So I might as well do it. Pave the way so to speak. Still, it'll be a staged approach since I'll have to pull and machine all four rotors, mount sensors, and run a LOT of brake line. To say nothing of figuring out where to put stuff. That's going to take more time than swapping out the pedal box.
Modern ABS is complicated & tied into several systems, including traction & stability control using a lot of computer.
Like I said, have fun.  I am confident that you are up to the challenge & are looking forward to it.
Yeah, actually there are a lot of systems that are standalone and need only power to function. The latest ones, probably not. But I'm specifically looking at '90-'94.
The more I think about this, and get input from others, the more I think the brake booster is the main thing and the ABS might be almost completely unnecessary.
I won't really be able to form an opinion of course until I have the booster installed but that should go relatively quickly once I have the parts in hand.
Here is the MC I plan to use. Banana for scale. A bit larger than I'd like but it bolts directly to the hydroboost unit and has a reasonably low profile plug-in reservoir available. The MC is Bimmer 7 series, reservoir is  that other not so cheap anymore German company of emissions cheaters. Bore is 1".
Look a lot like the OEM on my '79 B.
Dan B
Quote from: MGBV8 on October 29, 2026, 10:32:10 AMLook a lot like the OEM on my '79 B.
Looks like the one on my TR7 too.
Probably similar but the bore size and the stud spacing are different. I think MG is 13/16" and this is 1". Pretty sure on the MG the studs are 1/8" closer together. The spacing on the reservoir nipples may also be different, I think these are 75mm apart from memory, I may have ordered the wrong reservoir but I guess I'll find out Friday. It also needs a port for a line from the pump which it doesn't have. Looks like I got in too big of a hurry about ordering that part.
Still waiting on parts. The late pedal box is due tomorrow and the hydroboost should get here today. The reservoir should get here Friday. I should probably see if I can get a rebuild kit for the hydroboost.
I'm hopeful that once I swap out the pedal box I will have room beside it for the pump/accumulator unit.
Quote from: BlownMGB-V8 on November 04, 2026, 08:13:06 AMProbably similar but the bore size and the stud spacing are different. I think MG is 13/16" and this is 1". Pretty sure on the MG the studs are 1/8" closer together.
The mounting on the MGB brake master is a bit of an oddball.  I had to use an adapter to bolt the OEM to a dual brake booster.
The booster came in and it fits up to the MC correctly as far as appearances go. Odd thing, it has a black plastic insert that sticks out maybe 1/8" but gets pressed back in when the MC is bolted up, it appears to be spring loaded. Can't say I've seen that before. Overall length from the flange is 11" which is good but stickout into the pedal box could be a problem.
The reservoir also came in and the spacing on the spigots is right (85mm) but the spigots themselves are of a smaller size than the grommets were made for. Plus it needs extra fittings for the pump drain and return. Assuming the pump and booster isn't run as a separate system. I need to look at the plumbing for the Mk60e5 ABS unit to see where it gets it's pressure. I can use it for mock-up to evaluate reservoir size and placement. The pedal box should be in tomorrow.
#16
The brake bracket arrived yesterday and the fit is going to be tight (what isn't on this car?) but I think it'll work, which is pretty much the same as me saying I'ma make it work regardless.
An adapter plate between the bracket and the booster is needed for two reasons, because of the bolt pattern, but more importantly to get room inside the box for the pedal attachment.
As you can see, even trimming the rod back to the minimum it'll need some room and the only thing that immediately jumps out at me is spacing the booster forward. But there may be a better way. Trimming the piston won't work as seen here:
But creating a socket in the brake pedal arm itself could do it.
From the second image it's clear the brake arm has already been modified a bit and I've also modded brake arms, there's nothing sacrosact about them as long as they don't deform or break under pressure. It would be pretty simple to shorten the threaded part a bit and weld a blind tubular socket into the arm in place of the existing pin hole area. This might even let me simply bolt up the booster by drilling a new hole pattern and welding up the old ones. That would preserve the overall length and clear the headers. Yep, sounds like a plan.
I'm pretty sure the rod is held in by a threaded ferrule that takes a specific tang tool to remove but that wouldn't be hard to make, I've done them before for dashboard nuts. So I can avoid grit around the modification and precisely shorten the rod, important for the brake pedal dead zone.
Another consideration, the Hydroboost (ATE H31) runs on ATF with seal materials used accordingly so there are seal compatibility issues with the Lucas pump. Switching seal materials may not really be feasible so the simple answer is to use a compatible pump. But this isn't so simple. Such pumps are generally set up for continuous use with either transmissions or steering, completely unnecessary with brakes. So they need an accumulator and a switch at the very least, as well as a manifold block, usually containing a pressure relief valve. While I don't mind making up the manifold, the parts cost is starting to climb with an $80 pump, probably a $140 accumulator, and another hundred in the switch, pressure relief and fittings. So 300 here, 400 there, another couple hundred over there and we're at about a thousand without labor and that's just for the boosted brakes without the ABS and I still don't have a reservoir. I don't see anyone else doing this right away even though it is kinda cool... On the plus side I definitely should be able to put the parts together in such a way that it all sits on the firewall shelf.
Did you consider electric brakes?
No, do you have any info on them?
There are a number of universal kits out there.
Al Moor used ABSPowerbrake.com  A bit pricey.
Dan B
So I guess they replaced the vacuum servo with an electric servo motor?
So I looked into the electric brake boosters and decided to pivot. I found an electric brake servo from an Accord on ebay for about $140 including the MC and ordered it. I would have spent far more than that coming up with a pump/accumulator unit to run the hydroboost unit. It won't look as nice but it also won't be as likely to leak either so there's that. Once that comes in I'll see how it fits.
I'll need to resell the hydroboost but that may not be too hard, it's a very slick looking unit and I suspect a hot rodder will want it. It'll go perfect with a power steering pump.
Yet another event in this saga, wrong booster which it turns out isn't actually a booster at all. Don't get the one from the Hybrid. Back to the search, I asked to cancel the purchase. It apparently has to be a Bosch iBooster. More as we proceed.
