347 Stroker Powered Tr4A Modified
Started by Triumphant4A, December 03, 2025, 08:08:52 PM
Triumphant4A
Yep, same owner of the 302 Powered 4A modified.
I was not planning to repower the 4A, but a 347 all aluminum stroker engine made itself available to me at a price I couldn't refuse.  The 302 I have been running for the past 5+ years came from a wrecked Mustang project I bought with minimal documentation on the engine build.  It has been running really well, but has shown a bit of oil consumption and increasing lifter noise, so it had to come out anyway. The quote HP for the 347 (with full build records) is stupid high, so some de-tuning is planned.  I should get the new engine later this month and will update after I get started.  Not sure yet what I will do with the 302.
Triumphant4A
December 28 update- English and gearbox came out today, always sounds so easy. Fortunately, we found very few surprises- one of the most concerning was the discovery that two of the motor mount bolts had sheered. We will be using higher grade bolts when the 347 is slotted in!
I have added a few pics of today's progress, and one of the Dan Masters style motor mounts we fabricated for the 302 - will also work with the 347.
Triumphant4A
Looks like I need to down size pics, will load later
Triumphant4A
Resized pictures from today
Triumphant4A
#4
Good things take time, and I have been on hold waiting for the new 347 for the past few months.  But it wil finally get here this next week, and the timing couldn't be better.
With the 302 out of the car, we did compression and leak down tests that indicated a problem in cylinder 4.  With the valve cover off, it was clear that one of the roller keepers had popped out - and, yes with the head off, there were marks on the piston.  But the big surprise was that the block was cracked down the bore - I never would have suspected that!
Triumphant4A
It is finally here!
testing to see what fits and what doesn't
EFI manifold and rails will be the first pieces to come off
Also, sourcing a better remote oil filter housing than I had on the 302
Triumphant4A
A bit more progress today on making the new engine fit the old hole.
The 347 oil pan was fabricated for a Tiger with extra oil capacity - great idea but it did not clear the front crossmember.
A bit of trimming done, and it fits!
Next step will be to repair the damage I did to the Aviad oil pan.
I don't understand the extra metal on the bottom of the oil pan?
Triumphant4A
Hi Jim
Not so much "extra metal" as removed metal.
The pan is an Aviaid that was built with extra capacity for a '66 Tiger.
Unfortunately, it extended too far forward to clear the front cross member on the 4A.
So, the picture I posted earlier showed the pan "trimmed" to fit behind the cross member.
As an old woodworker, I am a fan of cut off a little piece, check, recut, check, recut, then fit.
I got lucky this time and only had to trim twice to get enough clearance to get it to slot in perfectly.
Picture shows it with a new front welded on (Aviad pans are steel with an anodized aluminum look coating that must be ground back first) and painted to match the block.
Although the welding looks a bit agricultural, it passed the leak test with flying colors.
Triumphant4A
I am adding a "pre-cut" pic as well to show how much needed to be removed to make it fit (1.4 inches). I will admit that I had more than a little hesitation to cutting up a $600 pan, but luckily it all went to plan.
Triumphant4A
Well, it was a chore,but the modified pan is back on the block.  I eklected to try the Fel Pro 1 piece steel and silicone pan gasket listed for a stock 302 pan. and after the third attempt, I realized something just wasn't right,  That "something" turned out to be the size of the main caps fouling the steel spine of the gasket on the passenger side by enough to prevent lining the pan bolts up properly with the gasket. Once spotted it was an easy fix with the bench grinder, but it would have been nice of Fel Pro to point out that the gasket was not a direct fit.
Triumphant4A
A bit more progress made today - The new engine is in on the mounts and all bolted in!
Now starts the fun part of rewiring, plumbing etc. I realized the otehr day that the water pump outlet position was different for the tiger than the 4A, so the one the 347b came with is off and I will be re-using the one I had on the 302. Fun, fun, fun
Triumphant4A
A short update tonight - for those familiar with the AFR Renegade heads, it will come as no surprise that fitting valve covers to clear the adjustable rockers is a chore!  The really tall Pep Boys stuff will provide clearance for the valves for sure, but they conflict with the EFI intakes on a lot of builds and with the steering on my build.  Fortunately, I had a decent deburring tool and enough patience to whittle away at my Aluminum Mustang style valve covers.  I was almost convinced that I would see daylight before I took off enough to make the clear, but somehow I found the sweat spot.  Picture shows the areas where surgery was needed. Not pretty, but they do now provide enough clearance to run with standard cork gaskets.
Yep. I had to do something similar to fit the repop MGBV8 valve covers to my TA-Rover heads with adjustable LS style rockers and also my Rover alloy covers on a set of late Rover heads with shaft style adjustable rockers. Seems to be a common problem, glad you found enough clearance.
Triumphant4A
Now that most of the bits are back in place, I am reminded just how tight everything is under this hood.  We will do a bit of tuning and adjusting before the aluminum fan shrouding and the hood are put in place, but I am pleased that he new engine is slotting right in without too much fuss.
Triumphant4A
Pardon the dust, the hood has been sitting in the wood shop for many months.
For those that don't already know, pulling the headlights out is the easiest way to remove and refit your hood on the 4A.  Engine in and running, hood on, lights back in their sockets, and a new set of driving lights installed through the grille.  Lights fold forward to allow the hood to open.  Nice when an idea works!
Hope to get it out of our shop and on the road for a dad's day cruise.
