Cruise control unit
Started by rficalora, December 05, 2008, 12:14:17 AM
Anyone know if the AudioVox CCS100 is a good choice for cruise control?  I know several people have used the AudioVox units & like them, but don't know if there's more than one version/model so don't know if that one is a good one.
There's a guy on the MGB Experience board who bought some from an auto parts store that's shutting down & he's selling them for $80 including shipping.
Rob
http://www.mgexperience.net/phorum/read.php?42,975470
Rob,
That is the standard universal model. It is a good unit. Do a search on the main MG forum over there. I remember that the stock 4 banger MG guys have been using the CCS-100 for years. I see them going for $60-$95 on Ebay.  I believe there is a model with a smaller actuator now. Some have an electric actuator. Sometime a vacuum reservoir can is needed for cars with big cams,  just like for power brake boosters.
I paid $25 for my NOS "antique" Sears cruise control.  It was made by Rostra. I tucked the actuator can mostly into the fenderwell hole over near the washer fluid reservoir.
http://www.rostra.com/
v8mgb
I installed the AudioVox CCS100 several years ago and it has worked great.  I have the control switches mounted in the ash tray and raised them up about a 1/2 inch using a small block of wood.   At the time (~2002) the AudioVox unit was the smallest, easy to hide and install.
I did discover that the AudioVox cruise control needs to detect a light bulb in the brake light circuit or it won't work.  LED brake lights will not allow the cruise control to engage unless you add a resistor in parallel.
Here is my web page on the installation
http://www.geocities.com/v8mgb/cruise/mg_cruise_control.html
MGB SS
How does this unit measure the MPH does it have a magnet/weight on the driveshaft?
Joe
v8mgb
> Joe
MPH is measured using engine RPM with a connection to the ignition coil.  The cruise control kit also comes with a magnet and sensor for the drive shaft.  I an using the tach/ignition coil method and it works great, fewer wires to deal with.
I presume that measuring actual speed (at the driveshaft) is only advantageous on a car with an auto transmission. If you use the clutch to change gears the cruise control will automatically kick out anyway, right?
v8mgb
> out anyway, right?
Yes the only time you would want to use the drive shaft sensor is with an automatic trans.
When the clutch is disengaged the control senses a sudden increase in enging RPM and releases the throttle.
I'm guessing that if you had an automatic with a lock-up torque converter (like Steve's 700r4) then you might get by with the tach sensor? It might act a little flaky if you didn't have the lock-up engaged though.
The AudioVox CCS100 can also be connected to the VSS.
Mine is an older model cruise packaged for Sears.  I used the driveshaft magnet. The clutch does not affect it since I didn't put a switch on it.
MGB SS
If the only input came from the coil then it would only hold RPMs not mph and I assume you would only use it in a set gear example how would you go up a steep hill with an auto trans?
 The VSS sensor is what I was hoping to hear.
Joe
